Merging sensor data from multiple temperature scenarios for vibration-based monitoring of civil structures, Structural Health Monitoring, vol.7, issue.2, p.129142, 2008. ,
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, p.101109, 2000. ,
DOI : 10.1016/S0005-1098(99)00093-X
Single sample modal identication of a nonstationary stochastic process, IEEE Transactions on Automatic Control, issue.1, p.306674, 1985. ,
Non-stationary consistency of subspace methods, IEEE Transactions on Automatic Control, issue.6, p.52974984, 2007. ,
On the distribution of the left singular vectors of a random matrix and its applications, Statistics & Probability Letters, vol.78, issue.15, p.7822752280, 2008. ,
DOI : 10.1016/j.spl.2008.01.097
Detecting changes in the ar parameters of a nonstationary arma process, Stochastics, vol.41, issue.1-2, p.137155, 1986. ,
DOI : 10.1016/0005-1098(76)90041-8
Reference-based stochastic subspace identication for output-only modal analysis, Mechanical Systems and Signal Processing, vol.13, issue.6, p.855878, 1999. ,
Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, vol.21, issue.6, 2007. ,
DOI : 10.1016/j.ymssp.2006.11.007
Dynamic monitoring of historical masonry structures for damage identication, Proceedings of the 26th International Modal Analysis Conference (IMAC-XXVI), 2008. ,
Uncertainty bounds on modal parameters obtained from stochastic subspace identication, Mechanical Systems and Signal Processing, vol.22, issue.4, p.948969, 2008. ,
Subspace Identication for Linear Systems: Theory, Implementation, Applications. Kluwer, 1996. ,
Null subspace-based damage detection of structures using vibration measurements, Mechanical Systems and Signal Processing, vol.20, issue.3, p.611626, 2006. ,
DOI : 10.1016/j.ymssp.2005.04.010
Advanced numerical computation of ? 2 tests for fault detection and isolation, 5th Symp. Fault Detection, Supervision and Safety for Technical Processes (SAFEPROCESS), p.211216, 2003. ,
