Instant Architecture
This paper presents a new method for the automatic modeling of architecture. Building designs are derived using split grammars, a new type of parametric set grammar based on the concept of shape. The paper also introduces an attribute matching system and a separate control grammar, which offer the flexibility required to model buildings using a large variety of different styles and design ideas. Through the adaptive nature of the design grammar used, the created building designs can either be generic or adhere closely to a specified goal, depending on the amount of data available.
instant_architecture.pdf (13.94 Mo)
Télécharger le fichier
Format : Figure, Image
