High-frequency asymptotic analysis of a dissipative transmission problem resulting in generalized impedance boundary conditions, Asymptot. Anal, vol.26, pp.257-283, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00347873
Robust and high-order effective boundary conditions for perfectly conducting scatterers coated by a thin dielectric layer, IMA J. Appl. Math, vol.67, pp.479-508, 2002. ,
The effect of a thin coating on the scattering of a time-harmonic wave for the Helmholtz equation, SIAM J. Appl. Math, vol.6, pp.1664-1693, 1996. ,
Asymptotic analysis of the scattering of a time-harmonic electromagnetic wave by a perfectly conducting metal coated with a thin dielectric shell, Asymptot. Anal, vol.57, pp.199-227, 2008. ,
FEM calculation of eddy current losses and forces in thin conducting sheets of test facilities for fusion reactor components, IEEE Trans. Magn, vol.28, pp.1509-1512, 1992. ,
Transient analysis of thin layers for the magnetic field shielding, IEEE Trans. Magn, vol.42, issue.4, pp.871-874, 2006. ,
Finite Elements: Theory, Fast Solvers, and Applications in Solid Mechanics, 2007. ,
Asymptotic expansion of the solution of an interface problem in a polygonal domain with thin layer, Asymptot. Anal, vol.50, issue.1, pp.121-173, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00001555
A simulation of magneto-hydrostatic phenomena in thin liquid layers of an aluminum electrolytic cell, IEEE Trans. Magn, vol.36, pp.1309-1312, 2000. ,
, Concepts Development Team. Webpage of Numerical C++ Library Concepts, vol.2, 2008.
Higher order generalized impedance boundary conditions in electromagnetic scattering problems, C. R. Physique, vol.7, issue.5, pp.533-542, 2006. ,
Concepts -an object-oriented software package for partial differential equations, M2AN Math. Model. Numer. Anal, vol.36, issue.5, pp.937-951, 2002. ,
A shell element for computing 3D eddy currents -Application to transformers, IEEE Trans. Magn, vol.31, pp.1360-1363, 1995. ,
Time-domain finite-element modeling of thin electromagnetic shells, IEEE Trans. Magn, 2008. ,
Generalized impedance boundary conditions for scattering by strongly absorbing obstacles: the scalar case, Math. Models Meth. Appl. Sci, vol.15, pp.1273-1300, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00743895
A boundary element analysis of magnetic shielding for electron microscopes, vol.17, pp.585-594, 1998. ,
Impedance boundary condition for vector potentials on thin layers and its application to integral equations, Eur. Phys. J. AP, vol.1, pp.103-109, 1998. ,
Example of shell models in analysing eddy-currents by boundary and finite element methods, IEEE Trans. Magn, vol.29, pp.1450-1455, 1993. ,
On approximate boundary conditions for electromagnetic fields on the surface of highly conducting bodies (in russian), pp.5-12, 1948. ,
On calculation of 3-D eddy currents in conducting and magnetic shells, IEEE Trans. Magn, vol.31, pp.1319-1324, 1995. ,
FE calculation of transient eddy currents in thin conductive sheets using dynamic boundary conditions. j-int-j-numer-model, vol.11, pp.307-316, 1998. ,
3D magnetic field analysis using special elements, IEEE Trans. Magn, vol.26, pp.2379-2381, 1990. ,
Approximate transmission conditions for time-harmonic Maxwell equations in a domain with thin layer, 2008. ,
Approximate transmission conditions through a weakly oscillating thin layer, Mathematical Methods in the Applied Sciences, vol.32, p.4, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00334772
Numerical simulation of thermal problems coupled with magnetohydrodynamic effects in aluminium cell, Appl. Math. Modell, 2008. ,
, , 2004.
High-order numerical modelling of highly conductive thin sheets, 2008. ,
Approximate Boundary Conditions in Electromagnetics. Institution of Electrical Engineers, 1995. ,
Propagation of Radio Waves, 1940. ,
, Lectures on Differential and Integral Equations, 1991.
, France e-mail: sebastien.tordeux@insa-toulouse.fr
