Compiling and securing cryptographic protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Processing Letters Année : 2010
Protocol narrations are widely used in security as semi-formal notations to specify conversations between roles. We define a translation from a protocol narration to the sequences of operations to be performed by each role. Unlike previous works, we reduce this compilation process to well-known decision problems in formal protocol analysis. This allows one to define a natural notion of prudent translation and to reuse many known results from the literature in order to cover more crypto-primitives. In particular this work is the first one to show how to compile protocols parameterised by the properties of the available operations.
inria-00527633 , version 1 (19-10-2010)
Yannick Chevalier, Michael Rusinowitch. Compiling and securing cryptographic protocols. Information Processing Letters, 2010, 110 (3), pp.116-122. ⟨10.1016/j.ipl.2009.11.004⟩. ⟨inria-00527633⟩
181 Consultations
0 Téléchargements
