Conference papers
Using Global Behavior Modeling to Improve QoS in Cloud Data Storage Services
Abstract : The cloud computing model aims to make large-scale data-intensive computing affordable even for users with limited financial resources, that cannot invest into expensive infrastructures necesssary to run them. In this context, MapReduce is emerging as a highly scalable programming paradigm that enables high-throughput data-intensive processing as a cloud service. Its performance is highly dependent on the underlying storage service, responsible to efficiently support massively parallel data accesses by guaranteeing a high throughput under heavy access concurrency. In this context, quality of service plays a crucial role: the storage service needs to sustain a stable throughput for each individual accesss, in addition to achieving a high aggregated throughput under concurrency. In this paper we propose a technique to address this problem using component monitoring, application-side feedback and behavior pattern analysis to automatically infer useful knowledge about the causes of poor quality of service and provide an easy way to reasonin about potential improvements. We apply our proposal to BlobSeer, a representative data storage service specifically designed to achieve high aggregated throughputs and show through extensive experimentation substantial improvements in the stability of individual data read accesses under MapReduce workloads.
Complete list of metadata
https://hal.inria.fr/inria-00527650
Contributor : Bogdan Nicolae Connect in order to contact the contributor
Submitted on : Wednesday, October 20, 2010 - 1:29:38 AM
Last modification on : Thursday, January 20, 2022 - 5:33:30 PM
Long-term archiving on: : Friday, January 21, 2011 - 2:30:10 AM
File
paper.pdf
Identifiers
Citation
Jesús Montes, Bogdan Nicolae, Gabriel Antoniu, Alberto Sánchez, María Pérez. Using Global Behavior Modeling to Improve QoS in Cloud Data Storage Services. CloudCom '10: Proceedings of the 2nd IEEE International Conference on Cloud Computing Technology and Science, Nov 2010, Indianapolis, United States. pp.304-311, ⟨10.1109/CloudCom.2010.33⟩. ⟨inria-00527650⟩
Share
Metrics
Record views
421
Files downloads
197
