On-board Component Fault Detection and Isolation Using the Statistical Local Approach, Automatica, vol.34, issue.11, p.13911416, 1998. ,
DOI : 10.1016/S0005-1098(98)00086-7
URL : https://hal.archives-ouvertes.fr/inria-00073437
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, p.101109, 2000. ,
DOI : 10.1016/S0005-1098(99)00093-X
In-ight monitoring of aeronautic structures: vibration-based on-line automated identication versus detection, IEEE Control Systems Magazine, vol.27, issue.5, p.2742, 2007. ,
Subspace-based algorithms for structural identication, damage detection, and sensor data fusion, Special Issue on Advances in Subspace-Based Techniques for Signal Processing and Communications, 2007. ,
Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios, Journal of Sound and Vibration, vol.275, issue.3-5, p.769794, 2004. ,
DOI : 10.1016/j.jsv.2003.07.016
URL : https://hal.archives-ouvertes.fr/inria-00071940
Theory of self-excited mechanical oscillations of helicopter rotors with hinged blades, 1958. ,
Ground and Air Resonance Characteristics of a Soft In-Plane Rigid-Rotor System, Journal of the American Helicopter Society, vol.14, issue.4, 1969. ,
DOI : 10.4050/JAHS.14.33
Analytical and a numerical ground resonance analysis of a conventionally articulated main rotor helicopter, 2007. ,
Helicopter Theory, 1994. ,
Propagation of structural uncertainty to linear aeroelastic stability, Computers & Structures, vol.88, issue.3-4, p.223236, 2010. ,
DOI : 10.1016/j.compstruc.2009.10.005
Inuence of elastomeric damper modeling on the dynamic response of helicopter rotors, p.349354, 1997. ,
Nonlinear analysis of helicopter ground resonance, 41st Structures, Structural Dynamics, and Materials Conference and Exhibit, p.383395, 2002. ,
DOI : 10.2514/6.2000-1690
Fast in-ight detection of utter onset -a statistical approach, AIAA Jal Guidance, Control, and Dynamics, vol.28, issue.3, p.431438, 2005. ,
Helicopter ground resonance -a spatial model analysis, Aeronautical Journal, vol.88, p.299308, 1984. ,
CONTINUOUS INSPECTION SCHEMES, Biometrika, vol.41, issue.1-2, p.100115, 1954. ,
DOI : 10.1093/biomet/41.1-2.100
Analysis and testing of a linear stroke magnetorheological damper, 39th AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics, and Materials Conference and Exhibit, 1998. ,
DOI : 10.2514/6.1998-2040
Instability zones identication in multiblade rotor dynamics, 11th Pan-American Congress of Applied Mechanics, 2010. ,
Inuence of landing gear design on helicopter ground resonance, p.452462, 1999. ,
Cusum test for utter monitoring of modal dynamics, Noise and Vibration Engineering Conference, 2006. ,
10 4.1.1 No damping case, p.11 ,
