A note on the generalized dumbbell problem, Proceedings of the American Mathematical Society, vol.123, issue.8, pp.2595-2599, 1995. ,
DOI : 10.1090/S0002-9939-1995-1257096-5
Neumann Eigenvalue Problems on Exterior Perturbations of the Domain, Journal of Differential Equations, vol.118, issue.1, pp.54-103, 1995. ,
DOI : 10.1006/jdeq.1995.1067
Mathematical Analysis of the Guided Modes of an Optical Fiber, SIAM Journal on Mathematical Analysis, vol.21, issue.6, pp.1487-1510, 1990. ,
DOI : 10.1137/0521082
URL : https://hal.archives-ouvertes.fr/hal-01010733
Scattering frequencies of resonators, Communications on Pure and Applied Mathematics, vol.37, issue.4, pp.549-563, 1973. ,
DOI : 10.1002/cpa.3160260408
Asymptotics for the low-lying eigenstates of the Schrödinger operator with magnetic field near corners, pp.899-931, 2006. ,
Mathematical analysis of conductive and superconductive transmission lines, in Mathematical and numerical aspects of wave propagation, SIAM, pp.12-21, 1998. ,
SIMULATION OF MUFFLER'S TRANSMISSION LOSSES BY A HOMOGENIZED FINITE ELEMENT METHOD, Journal of Computational Acoustics, vol.12, issue.03, pp.447-474, 2004. ,
DOI : 10.1142/S0218396X04002304
Eigenvalues and Resonances for Domains with Tubes: Neumann Boundary Conditions, Journal of Differential Equations, vol.115, issue.2, pp.458-476, 1995. ,
DOI : 10.1006/jdeq.1995.1023
Lower bounds on the interaction between cavities connected by a thin tube, Duke Math, J, vol.73, pp.163-176, 1994. ,
Asymptotic expansion of the solution of an interface problem in a polygonal domain with thin layer, Asymptot. Anal, vol.50, pp.121-173, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00001555
Eigenmode Asymptotics in Thin Elastic Plates, Journal de Math??matiques Pures et Appliqu??es, vol.78, issue.9, pp.78-925, 1999. ,
DOI : 10.1016/S0021-7824(99)00138-5
URL : http://doi.org/10.1016/s0021-7824(99)00138-5
Growth of rounding errors and the repetitivity of large eddy simulations, AIAA Journal, pp.46-1773, 2008. ,
Remarks on the behavior of certain eigenvalues on a singularly perturbed domain with several thin channels, Comm. Partial Differential Equations, vol.17, pp.523-552, 1992. ,
Matching of Asymptotic Expansions for Wave Propagation in Media with Thin Slots I: The Asymptotic Expansion, Multiscale Modeling & Simulation, vol.5, issue.1, pp.304-336, 2006. ,
DOI : 10.1137/05064494X
URL : https://hal.archives-ouvertes.fr/inria-00527588
Eigenvalues of the Laplacian in Two Dimensions, SIAM Review, vol.26, issue.2, pp.163-193, 1984. ,
DOI : 10.1137/1026033
Justification et amlioration de modles d'antennes patch par la mthode des dveloppements asymptotiques raccords, 2008. ,
Large-eddy simulation of a bi-periodic turbulent flow with effusion, Journal of Fluid Mechanics, vol.117, pp.27-65, 2008. ,
DOI : 10.1017/S0022112006004034
URL : https://hal.archives-ouvertes.fr/hal-00820464
Electrostatic screening, Journal of Mathematical Physics, vol.16, issue.2, pp.284-288, 1975. ,
DOI : 10.1063/1.522539
IntroductionàIntroductionà l'analyse numérique deséquationsdeséquations aux dérivées partielles, Collection Mathématiques Appliquées pour la Ma??triseMa??trise. [Collection of Applied Mathematics for the Master's Degree], 1983. ,
Acoustic fluid flow through holes and permeability of perforated walls, Journal of Mathematical Analysis and Applications, vol.87, issue.2, pp.427-453, 1982. ,
DOI : 10.1016/0022-247X(82)90133-0
Méthodes asymptotiques pour la propagation des ondes dans les milieux comportant des fentes, 2004. ,
Matching and multiscale expansions for a model singular perturbation problem, Comptes Rendus Mathematique, vol.343, issue.10, pp.343-637, 2006. ,
DOI : 10.1016/j.crma.2006.10.010
URL : https://hal.archives-ouvertes.fr/hal-00453366
Matching Problems Involving Flow through Small Holes, Advances in applied mechanics, pp.89-158, 1975. ,
DOI : 10.1016/S0065-2156(08)70056-5
Perturbation Method in Fluid Mechanics, Journal of Applied Mechanics, vol.43, issue.1, 1975. ,
DOI : 10.1115/1.3423785
Vila Matching of Asymptotic Expansions for a 2-D eigenvalue problem with two cavities linked by a narrow hole 09-16 D. Kressner, C. Tobler Krylov subspace methods for linear systems with tensor product structure 09-15 R. Granat, B. Kågström, D. Kressner A novel parallel QR algorithm for hybrid distributed memory HPC systems 09-14 M. Gutknecht IDR explained 09-13 Quintana-Orti Reduction to condensed forms for symmetric eigenvalue problems on multi-core architectures 09-12 M. Stadelmann Matrixfunktionen -Analyse und Implementierung 09-11 G. Widmer An efficient sparse finite element solver for the radiative transfer equation 09-10 Varga Die SLICOT-Toolboxen für Matlab 09-09 H. Heumann, R. Hiptmair A semi-Lagrangian method for convection of differential forms 09-08 M. Bieri A sparse composite collocation finite element method for elliptic sPDEs 09-07 M. Bieri, R. Andreev, C. Schwab Sparse tensor discretization of elliptic sPDEs 09-06 A. Moiola Approximation properties of plane wave spaces and application to the analysis of the plane wave discontinuous Galerkin method 09-05 D. Kressner A block Newton method for nonlinear eigenvalue problems 09, treatise on the theory of Bessel functions Convergence analysis of Finite Element Methods for H(curl;?)-elliptic interface problems 09-03 A. Chernov, T. von Petersdorff, C. Schwab Exponential convergence of hp quadrature for integral operators with Gevrey kernels, 1944. ,
