An improved unsplit and convolutional Perfectly Matched Layer (CPML) absorbing technique for the Navier-Stokes equations using cut-off frequency shift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Modeling in Engineering and Sciences Année : 2010
Fichier non déposé
inria-00528457 , version 1 (21-10-2010)
Roland Martin, Carlos Couder-Castaneda. An improved unsplit and convolutional Perfectly Matched Layer (CPML) absorbing technique for the Navier-Stokes equations using cut-off frequency shift. Computer Modeling in Engineering and Sciences, 2010, 63 (1), pp.47-78. ⟨10.3970/cmes.2010.063.047⟩. ⟨inria-00528457⟩
104 Consultations
0 Téléchargements
