Column generation for studying capacity and energy trade-off in LTE-like network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Anis Ouni
Hervé Rivano
Fabrice Valois
In this paper, we focus on broadband wireless mesh networks like 3GPP LTE-Advanced. This technology is a key enabler for next generation cellular networks which are about to increase by an order of magnitude the capacity provided to users. Such an objective needs a significative densification of cells which requires an efficient backhauling infrastructure. In many urban areas as well as under-developed countries, wireless mesh networking is the only available solu- tion. Besides, economical and environmental concerns require that the energy expenditure of such infrastructure is optimized. We propose a multi-objective analysis of the correlation between capacity and energy consumption of LTE-like wireless mesh networks. We provide a linear programing modeling using column generation for an efficient computation of the Pareto front between these objectives. Based on this model, we observe that there is actually no significant capacity against energy trade-off.
RR-7437.pdf (631.14 Ko) Télécharger le fichier
inria-00529070 , version 1 (24-10-2010)
inria-00529070 , version 2 (16-11-2010)
  • HAL Id : inria-00529070 , version 2
Anis Ouni, Hervé Rivano, Fabrice Valois. Column generation for studying capacity and energy trade-off in LTE-like network. [Research Report] RR-7437, INRIA. 2010. ⟨inria-00529070v2⟩
153 Consultations
150 Téléchargements
