Performance of hardware compressed main memory, Proceedings HPCA Seventh International Symposium on High-Performance Computer Architecture, pp.73-81, 2001. ,
DOI : 10.1109/HPCA.2001.903253
Adaptive cache compression for high-performance processors, ISCA '04: Proceedings of the 31st annual International Symposium on Computer Architecture, pp.212-223, 2004. ,
Frequent pattern compression: A significance-based compression scheme for L2 caches, 2004. ,
Improving Web Server Performance Through Main Memory Compression, 2008 14th IEEE International Conference on Parallel and Distributed Systems, pp.303-310, 2008. ,
DOI : 10.1109/ICPADS.2008.15
URL : http://upcommons.upc.edu/bitstream/2117/15688/1/icpads08.pdf
Heap compression for memory-constrained java environments, OOPSLA '03: Proceedings of the 18th annual conference on Object-Oriented Programing, Systems, Languages, and Applications, pp.282-301, 2003. ,
DOI : 10.1145/949305.949330
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.4.3091
Adaptive compressed caching: design and implementation, Proceedings. 15th Symposium on Computer Architecture and High Performance Computing, pp.10-18, 2003. ,
DOI : 10.1109/CAHPC.2003.1250316
The compression cache: Using on-line compression to extend physical memory, USENIX Winter: Proceedings of 1993 Winter USENIX Conference, pp.519-529, 1993. ,
Zero-content augmented caches, Proceedings of the 23rd international conference on Conference on Supercomputing, ICS '09, pp.46-55, 2009. ,
DOI : 10.1145/1542275.1542288
URL : https://hal.archives-ouvertes.fr/inria-00337742
A robust main-memory compression scheme, 32nd International Symposium on Computer Architecture (ISCA'05), pp.74-85, 2005. ,
DOI : 10.1109/ISCA.2005.6
Algorithms and data structures for compressed-memory machines, IBM Journal of Research and Development, vol.45, issue.2, pp.245-258, 2001. ,
DOI : 10.1147/rd.452.0245
Design and analysis of internal organizations for compressed random access memories, 1998. ,
On internal organization in compressed random-access memories, IBM Journal of Research and Development, vol.45, issue.2, pp.259-270, 2001. ,
DOI : 10.1147/rd.452.0259
Parallel compression with cooperative dictionary construction, Proceedings of Data Compression Conference, DCC '96, pp.200-209, 1996. ,
DOI : 10.1109/DCC.1996.488325
A Unified Compressed Memory Hierarchy, 11th International Symposium on High-Performance Computer Architecture, pp.201-212, 2005. ,
DOI : 10.1109/HPCA.2005.4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.8974
A selective compressed memory system by on-line data decompressing, Euromicro '99: Proceedings of the 25th annual Euromicro Conference, pp.224-227, 1999. ,
Memory state compressors for giga-scale checkpoint/restore Improving system performance with compressed memory, PACT '05: Proceedings of the 14th annual international conference on Parallel Architectures and Compilation Techniques IPDPS '01: Proceedings of the 15th International Parallel and Distributed Processing Symposium, pp.303-314, 2001. ,
Z-rays: Divide arrays and conquer speed and flexibility, PLDI '10: Proceedings of the 2010 international conference on Programming Language Design and Implementation, pp.471-482, 2010. ,
No bit left behind, Proceedings of the 7th international symposium on Memory management , ISMM '08, pp.111-120, 2008. ,
DOI : 10.1145/1375634.1375651
Decoupled sectored caches, ISCA '94: Proceedings of the 21st annual International Symposium on Computer Architecture, pp.384-393, 1994. ,
DOI : 10.1145/192007.192072
IBM Memory Expansion Technology (MXT), IBM Journal of Research and Development, vol.45, issue.2, pp.271-285, 2001. ,
DOI : 10.1147/rd.452.0271
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.9649
The case for compressed caching in virtual memory systems, ATEC '99: Proceedings of the annual conference on USENIX Annual Technical Conference, pp.101-116, 1999. ,
A universal algorithm for sequential data compression, IEEE Transactions on Information Theory, vol.23, issue.3, pp.337-343, 1977. ,
DOI : 10.1109/TIT.1977.1055714
