A low-cost memory architecture with NAND XIP for mobile embedded systems, Proceedings of the 1st IEEE/ACM/IFIP international conference on Hardware/software codesign & system synthesis , CODES+ISSS '03, pp.138-143, 2003. ,
DOI : 10.1145/944682.944684
Application specific non-volatile primary memory for embedded systems, Proceedings of the 6th IEEE/ACM/IFIP international conference on Hardware/Software codesign and system synthesis, CODES/ISSS '08, pp.31-36, 2008. ,
DOI : 10.1145/1450135.1450144
A NOR Emulation Strategy over NAND Flash Memory, 13th IEEE International Conference on Embedded and Real-Time Computing Systems and Applications (RTCSA 2007), pp.95-102, 2007. ,
DOI : 10.1109/RTCSA.2007.9
A new NAND-type flash memory package with smart buffer system for spatial and temporal localities, Journal of Systems Architecture, vol.51, issue.2, 2005. ,
DOI : 10.1016/j.sysarc.2004.10.002
Source code arrangement of embedded java virtual machine for nand flash memory, pp.152-157, 2007. ,
Swl: a search-while-load demand paging scheme with nand flash memory, LCTES '07: Proceedings of the 2007 ACM SIGPLAN/SIGBED conference on Languages, compilers, and tools for embedded systems, pp.217-226, 2007. ,
Removing the memory limitations of sensor networks with flash-based virtual memory, SIGOPS Oper. Syst. Rev, pp.41-131, 2007. ,
Real-Time Program Execution on NAND Flash Memory for Portable Media Players, 2008 Real-Time Systems Symposium, pp.244-255, 2008. ,
DOI : 10.1109/RTSS.2008.27
Improving the Demand Paging Performance with NAND-type Flash Memory, 2008 International Conference on Computational Sciences and Its Applications, pp.157-163, 2008. ,
DOI : 10.1109/ICCSA.2008.69
Demand paging for onenand TM flash execute-in-place, CODES+ISSS '06: Proceedings of the 4th international conference on Hardware/software codesign and system synthesis, pp.229-234, 2006. ,
Compiler-assisted demand paging for embedded systems with flash memory, Proceedings of the fourth ACM international conference on Embedded software , EMSOFT '04, pp.114-124, 2004. ,
DOI : 10.1145/1017753.1017775
Architecture exploration of nand flash-based multimedia card, DATE '08: Proceedings of the conference on Design, automation and test in Europe, pp.218-223, 2008. ,
Energy and performance optimization ofdemand paging with onenand flash In: Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.27, issue.11, pp.1969-1982, 2008. ,
Performance evaluation of cache replacement policies for the SPEC CPU2000 benchmark suite, Proceedings of the 42nd annual Southeast regional conference on , ACM-SE 42, pp.267-272, 2004. ,
DOI : 10.1145/986537.986601
A study of replacement algorithms for a virtual-storage computer, IBM Systems Journal, vol.5, issue.2, pp.78-101, 1966. ,
DOI : 10.1147/sj.52.0078
The locality principle, 2005. ,
Efficient off-board deployment and customization of virtual machine-based embedded systems, ACM Transactions on Embedded Computing Systems, vol.9, issue.3, 2010. ,
DOI : 10.1145/1698772.1698779
