From Neuron to Neural Networks dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The European Physical Journal. Special Topics Année : 2006
This paper presents an overview of some techniques and concepts coming from dynamical system theory and used for the analysis of dynamical neural networks models. In a first section, we describe the dynamics of the neuron, starting from the Hodgkin-Huxley description, which is somehow the canonical description for the ``biological neuron''. We discuss some models reducing the Hodgkin-Huxley model to a two dimensional dynamical system, keeping one of the main feature of the neuron: its excitability. We present then examples of phase diagram and bifurcation analysis for the Hodgin-Huxley equations. Finally, we end this section by a dynamical system analysis for the nervous flux propagation along the axon. We then consider neuron couplings, with a brief description of synapses, synaptic plasticiy and learning, in a second section. We also briefly discuss the delicate issue of causal action from one neuron to another when complex feedback effects and non linear dynamics are involved. The third section presents the limit of weak coupling and the use of normal forms technics to handle this situation. We consider then several examples of recurrent models with different type of synaptic interactions (symmetric, cooperative, random). We introduce various techniques coming from statistical physics and dynamical systems theory. A last section is devoted to a detailed example of recurrent model where we go in deep in the analysis of the dynamics and discuss the effect of learning on the neuron dynamics. We also present recent methods allowing the analysis of the non linear effects of the neural dynamics on signal propagation and causal action. An appendix, presenting the main notions of dynamical systems theory useful for the comprehension of the chapter, has been added for the convenience of the reader.
inria-00529558 , version 1 (25-10-2010)
Bruno Cessac, M. Samuelides. From Neuron to Neural Networks dynamics. The European Physical Journal. Special Topics, 2006, 142 (1), pp.7-88. ⟨10.1140/epjst/e2007-00058-2⟩. ⟨inria-00529558⟩
192 Consultations
0 Téléchargements
