Validating register allocation and spilling - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
Following the translation validation approach to high-assurance compilation, we describe a new algorithm for validating a posteriori the results of a run of register allocation. The algorithm is based on backward dataflow inference of equations between variables, registers and stack locations, and can cope with sophisticated forms of spilling and live range splitting, as well as many forms of architectural irregularities such as overlapping registers. The soundness of the algorithm was mechanically proved using the Coq proof assistant.
validation-regalloc.pdf (172.01 Ko) Télécharger le fichier
Dates and versions
inria-00529841 , version 1 (28-10-2010)
Identifiers
Cite
Silvain Rideau, Xavier Leroy. Validating register allocation and spilling. Compiler Construction 2010, Mar 2010, Paphos, Cyprus. pp.224-243, ⟨10.1007/978-3-642-11970-5_13⟩. ⟨inria-00529841⟩
329 View
210 Download
Share
