New interface
Conference papers
Coexistence of radio networks using Aloha
Bartlomiej Blaszczyszyn 1 Paul Mühlethaler 2 Skander Banaouas 2
1 TREC - Theory of networks and communications
DI-ENS - Département d'informatique - ENS Paris, Inria Paris-Rocquencourt
2 HIPERCOM - High performance communication
Inria Paris-Rocquencourt, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, X - École polytechnique, CNRS - Centre National de la Recherche Scientifique : UMR
Abstract : In this paper we use an analytical model to study how two radio networks: a primary network and a secondary network can coexist within the same area. We use a very simple protocol, Aloha, for both radio networks, and tools borrowed from stochastic geometry to model the performance of our two networks. We show that the primary network and the secondary network can adapt their transmission parameters simultaneously to achieve the following goal: the primary network maintains its performance with a maximum and fixed degradation whereas the secondary network maximizes its transmission throughput. In practice this involves the primary network adapting its transmission power and the secondary network its transmission probability. We also study the gain in performance when the secondary network nodes only transmit when their receivers are at minimum distance from any transmitter nodes in the primary network (constrained distance deployment). We obtain the following result: when there is no constraint used for the secondary network (free deployment), it can offer a low (but not completely negligible) density of successful transmissions when the capture threshold in primary network T1 is small. If we optimize the density of successful transmissions for the selected nodes in the secondary network which are transmitting to receivers at a minimum distance from any node in the primary network then the per node throughput for these selected nodes can be very significantly increased. However with this optimization the total network throughput for the secondary network is also slightly reduced. If we use a constrained distance deployment for the secondary network (only nodes whose receivers at a minimum distance from the primary network) the per node throughput can be very significantly increased and the total network throughput for the secondary network is increased.
Document type :
Conference papers
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00529904
Contributor : Bartlomiej Blaszczyszyn Connect in order to contact the contributor
Submitted on : Tuesday, October 26, 2010 - 11:26:35 PM
Last modification on : Tuesday, October 25, 2022 - 4:17:34 PM
Long-term archiving on: : Friday, October 26, 2012 - 12:25:42 PM
File
cognitive9.pdf
Identifiers
Collections
Citation
Bartlomiej Blaszczyszyn, Paul Mühlethaler, Skander Banaouas. Coexistence of radio networks using Aloha. IFIP Wireless Days Conference, Oct 2010, Venice, Italy. ⟨10.1109/WD.2010.5657746⟩. ⟨inria-00529904⟩
Share
Metrics
Record views
342
Files downloads
213
