LSPI with Random Projections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
Mohammad Ghavamzadeh
  • Fonction : Auteur
  • PersonId : 868946
Alessandro Lazaric
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
We consider the problem of reinforcement learning in high-dimensional spaces when the number of features is bigger than the number of samples. In particular, we study the least-squares temporal difference (LSTD) learning algorithm when a space of low dimension is generated with a random projection from a high-dimensional space. We provide a thorough theoretical analysis of the LSTD with random projections and derive performance bounds for the resulting algorithm. We also show how the error of LSTD with random projections is propagated through the iterations of a policy iteration algorithm and provide a performance bound for the resulting least-squares policy iteration (LSPI) algorithm.
Informatique
randproj-lspi.pdf (186.35 Ko) Télécharger le fichier
inria-00530762 , version 1 (29-10-2010)
  • HAL Id : inria-00530762 , version 1
Mohammad Ghavamzadeh, Alessandro Lazaric, Odalric Maillard, Rémi Munos. LSPI with Random Projections. [Technical Report] 2010. ⟨inria-00530762⟩
209 Consultations
204 Téléchargements
