DSP-based speed adaptive flux observer of induction motor, IEEE Transactions on Industry Applications, vol.29, issue.2, pp.344-348, 1993. ,
DOI : 10.1109/28.216542
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
DOI : 10.1016/S0005-1098(97)00209-4
Chattering avoidance by second-order sliding mode control, IEEE Transactions on Automatic Control, vol.43, issue.2, pp.241-246, 1998. ,
DOI : 10.1109/9.661074
Observability conditions of induction motors at low frequencies, Proceedings of the 39th IEEE Conference on Decision and Control (Cat. No.00CH37187), 2000. ,
DOI : 10.1109/CDC.2000.914093
Sliding mode control in engineering, Control Engineering Series, vol.11 ,
DOI : 10.1201/9780203910856
Sensorless Speed Control of Induction Motor, American Control Conference, 2004. ,
Combination of signal injection and neural networks for sensorless control of inverter fed induction machines, 2004 IEEE 35th Annual Power Electronics Specialists Conference (IEEE Cat. No.04CH37551), pp.2300-2305, 2004. ,
DOI : 10.1109/PESC.2004.1355480
Direct Torque Control of PWM Inverter-Fed AC Motors???A Survey, IEEE Transactions on Industrial Electronics, vol.51, issue.4, pp.744-755, 2004. ,
DOI : 10.1109/TIE.2004.831717
Modeling and High-Performance Control of Electric Machines, IEEE Series on Power Engineering, 2005. ,
DOI : 10.1002/0471722359
Observation et commande de la machine asynchrone sans capteur mcanique, 2005. ,
Super twisting algorithm based stepby-step sliding mode observers for nonlinear systems with unknown inputs, International Journal of Systems Science, vol.38, issue.10, 2007. ,
Contribution la synthse d'observateurs non linaires pour des classes de systmes dynamiques hybrids, 2007. ,
Super twisting algorithmbased step-by-step sliding mode observers for nonlinear systems with unknown inputs, Int. J. Systems Science, vol.38, issue.10, pp.803-815, 2007. ,
Speed and rotor flux estimation of induction machines using a two-stage extended Kalman filterstar, Automatica, vol.37, issue.1, pp.107-112, 2009. ,
On Sensorless Induction Motor Drives: Sliding-Mode Observer and Output Feedback Controller, IEEE Transactions on Industrial Electronics, vol.56, issue.9, pp.3404-3413, 2009. ,
DOI : 10.1109/TIE.2009.2026387
URL : https://hal.archives-ouvertes.fr/inria-00531078
A robust output feedback controller for induction motor drivers: new design and experimental validation, International Journal of Control ,
