Extended kalman filter tuning in sensorless PMSM drives, IEEE Transactions on Industry Applications, vol.39, issue.6, pp.1741-1747, 2003. ,
DOI : 10.1109/TIA.2003.818991
A nonlinear reduced order observer for permanent magnet synchronous motors, IEEE Transactions on Industrial Electronics, vol.43, issue.4, pp.492-497, 1996. ,
DOI : 10.1109/41.510641
LMI-Based Sensorless Control of Permanent-Magnet Synchronous Motors, IEEE Transactions on Industrial Electronics, vol.54, issue.5, pp.2769-2778, 2007. ,
DOI : 10.1109/TIE.2007.899829
Signal injection in sensor-less PMSM drives equipped with inverter output filter, IEEE PCC'07, pp.1105-1110, 2007. ,
Sensorless drive of surface-mounted permanent-magnet motor by high-frequency signal injection based on magnetic saliency, IEEE Transactions on Industry Applications, vol.39, issue.4, pp.1031-1039, 2003. ,
DOI : 10.1109/TIA.2003.813734
An improved sliding mode observer for speed sensor-less vector control drive of PMSM, IEEE IPEMC'06, pp.1-5, 2006. ,
On Sensorless Induction Motor Drives: Sliding-Mode Observer and Output Feedback Controller, IEEE Transactions on Industrial Electronics, vol.56, issue.9, pp.3404-3413, 2009. ,
DOI : 10.1109/TIE.2009.2026387
URL : https://hal.archives-ouvertes.fr/inria-00531078
A robust sensorless output feedback controller of the induction motor drives: new design and experimental validation, International Journal of Control, vol.35, issue.1, pp.484-497, 2010. ,
DOI : 10.1007/978-3-642-84379-2
URL : https://hal.archives-ouvertes.fr/inria-00450963
Hybrid rotor position observer for wide speed-range sensorless PM motor drives including zero speed, IEEE Transactions on Industrial Electronics, vol.53, issue.2, pp.373-378, 2006. ,
DOI : 10.1109/TIE.2006.870867
Hwang et al, Sensor-less Control of PMSM in high speed range with iterative sliding mode observer, IEEE APEC, vol.2, pp.1111-1116, 2004. ,
Sensor-less initial rotor position estimation of surface permanent magnet synchronous motor, IEEE Trans. Ind. Appl, vol.36, issue.6, pp.1598-1603, 2000. ,
A permanent magnet motor drive without a shaft sensor, Industry Applications Society Annual Meeting, pp.553-558, 1990. ,
Observability Study and Observer-Based Interconnected Form for sensor-less Induction Motor, IEEE CDC, pp.1240-1245, 2006. ,
DOI : 10.1109/cdc.2006.376711
Global observability analysis of sensorless induction motors, Automatica, vol.40, issue.6, pp.1079-1085, 2004. ,
DOI : 10.1016/j.automatica.2004.01.020
A New Control method for Permanent Magnet Synchronous Machines with Observer, 35th annual IEEE Pow, Specialists Conf, pp.1004-1408, 2004. ,
Synchronous Machine Drive Observability Analysis for sensor-less Control Design, 16th IEEE Int. Conf. on Cont. and Appl., oct, pp.1113-1117, 2007. ,
Synchronous Machine Drive Observability Analysis and sensor-less Control Design, 2nd IEEE Int. Conf. on Pow. and Energ., dec, pp.265-270, 2008. ,
Super Twisting Observer for Sensor-less Control of PMSM, In proc, of the International IASTED conferences, Control and Applications, pp.129-135, 2009. ,
Observability Analysis of PMSM, In proc, IEEE Int. conf., Sign. Circ. and Syst, pp.1-6, 2009. ,
Chattering avoidance by second-order sliding mode control, IEEE Transactions on Automatic Control, vol.43, issue.2, pp.241-246, 1998. ,
DOI : 10.1109/9.661074
An extended electromotive force model for sensorless control of interior permanent-magnet synchronous motors, IEEE Transactions on Industrial Electronics, vol.50, issue.2, pp.288-295, 2003. ,
DOI : 10.1109/TIE.2003.809391
A HOSM Observer with an improved zero speed position estimation for Surface PMSM Control, IEEE Int. Conf. on Control and Application, 2010. ,
Nonlinear controllability and observability, IEEE Transactions on Automatic Control, vol.22, issue.5, pp.728-740, 1977. ,
DOI : 10.1109/TAC.1977.1101601
Observability for any u(t) of a class of nonlinear systems, 1980 19th IEEE Conference on Decision and Control including the Symposium on Adaptive Processes, pp.922-926, 1981. ,
DOI : 10.1109/CDC.1980.271933
Higher order sliding modes as a natural phenomenon in control theory, pp.107-133, 1996. ,
DOI : 10.1007/BFb0027563
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
DOI : 10.1016/S0005-1098(97)00209-4
Sliding mode Control in engineering, 2002. ,
DOI : 10.1201/9780203910856
Boiliveau (IRCcyN), L. Loron (IREENA), 2008. ,
