On Sensorless Induction Motor Drives: Sliding Mode Observer and Output Feedback Controller - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Industrial Electronics Année : 2009
In this paper, a sensorless output feedback controller is designed in order to drive the Induction Motor (IM) without the use of flux and speed sensors. Firstly, a new sliding mode observer that uses only the measured stator currents is synthesized to estimate the speed, the flux and the load torque. Secondly, a current-based field oriented sliding mode control is developed so as to steer the estimated speed and flux magnitude to the desired references. Stability analysis based on Lyapunov theory is also presented in order to guarantee the closed loop stability of the proposed observer-control system. Two experimental results for a 1.5-kW IM are presented and analyzed by taking into account the unobservability phenomena of the Sensorless Induction Motor (SIM).
Automatique
ALL_08-TIE-1220.pdf (823.41 Ko) Télécharger le fichier
inria-00531078 , version 1 (01-11-2010)
  • HAL Id : inria-00531078 , version 1
Malek Ghanes, Gang Zheng. On Sensorless Induction Motor Drives: Sliding Mode Observer and Output Feedback Controller. IEEE Transactions on Industrial Electronics, 2009, Vol.56 (N°9), p. 3404-3413. ⟨inria-00531078⟩
245 Consultations
1163 Téléchargements
