Tolerating memory leaks, OOPSLA: Proceedings of the 23rd Annual ACM SIGPLAN Conference on Object-Oriented Programming, Systems, Languages, and Applications, pp.109-126, 2008. ,
Distribution Map, 2006 22nd IEEE International Conference on Software Maintenance, pp.203-212, 2006. ,
DOI : 10.1109/ICSM.2006.22
High-level polymetric views of condensed run-time information, Eighth European Conference on Software Maintenance and Reengineering, 2004. CSMR 2004. Proceedings., pp.309-318, 2004. ,
DOI : 10.1109/CSMR.2004.1281433
Visualizing the behavior of object-oriented systems, Proceedings of International Conference on Object-Oriented Programming Systems, Languages, and Applications (OOPSLA'93), pp.326-337, 1993. ,
Modeling objectoriented program execution, Proceedings of the European Conference on Object-Oriented Programming, pp.163-182, 1994. ,
Correlating Features and Code Using a Compact Two-Sided Trace Analysis Approach, Ninth European Conference on Software Maintenance and Reengineering, pp.314-323, 2005. ,
DOI : 10.1109/CSMR.2005.21
Garbage Collection: Algorithms for Automatic Dynamic Memory Management, 1996. ,
The information mural: Increasing information bandwidth in visualizations, 1996. ,
Visualizing interactions in program executions, Proceedings of International Conference on Software Engineering (ICSE'97), pp.360-370, 1997. ,
Polymetric views - A lightweight visual approach to reverse engineering, IEEE Transactions on Software Engineering, vol.29, issue.9, pp.782-795, 2003. ,
DOI : 10.1109/TSE.2003.1232284
Interactive visualization of design patterns can help in framework understanding, Proceedings ACM International Conference on Object-Oriented Programming Systems, Languages and Applications (OOPSLA'95), pp.342-357, 1995. ,
Program explorer: A program visualizer for C++, Proceedings of Usenix Conference on Object-Oriented Technologies, pp.39-54, 1995. ,
The story of Moose: an agile reengineering environment, Proceedings of the European Software Engineering Conference (ESEC/FSE'05), pp.1-10, 2005. ,
Recovering high-level views of object-oriented applications from static and dynamic information, Proceedings IEEE International Conference on Software Maintenance, 1999 (ICSM'99). 'Software Maintenance for Business Change' (Cat. No.99CB36360), pp.13-22, 1999. ,
DOI : 10.1109/ICSM.1999.792487
Visualizing Java in action, Proceedings of SoftVis 2003 (ACM Symposium on Software Visualization), pp.57-66, 2003. ,
Software Visualization ? Programming as a Multimedia Experience, 1998. ,
On the relationships between static and dynamic models in reverse engineering Java software, Sixth Working Conference on Reverse Engineering (Cat. No.PR00303), pp.304-313, 1999. ,
DOI : 10.1109/WCRE.1999.806969
Visualizing dynamic software system information through high-level models, Proceedings of International Conference on Object-Oriented Programming Systems, Languages, and Applications (OOPSLA'98), pp.271-283, 1998. ,
