Randomness on Computable Probability Spaces—A Dynamical Point of View - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory of Computing Systems Année : 2011
We extend the notion of randomness (in the version introduced by Schnorr) to computable probability spaces and compare it to a dynamical notion of randomness: typicality. Roughly, a point is typical for some dynamic, if it follows the statistical behavior of the system (Birkhoff's pointwise ergodic theorem). We prove that a point is Schnorr random if and only if it is typical for every mixing computable dynamics. To prove the result we develop some tools for the theory of computable probability spaces (for example, morphisms) that are expected to have other applications.
TOCScorrected.pdf (215.49 Ko) Télécharger le fichier
inria-00531640 , version 1 (05-11-2010)
Peter Gacs, Mathieu Hoyrup, Cristobal Rojas. Randomness on Computable Probability Spaces—A Dynamical Point of View. Theory of Computing Systems, 2011, 48 (3), pp.465--485. ⟨10.1007/s00224-010-9263-x⟩. ⟨inria-00531640⟩
204 Consultations
121 Téléchargements
