Abstract : This paper deals with the problem of automatic interpretation of oceanographic images for vortices detection, modelization and tracking. We present a framework allowing the vortices detection. The processing is split into three parts: apparent motion computation from the image sequence, local interpretation of apparent motion and geometric modelization of the vortices. This scheme allows an efficient approach for vortices segmentation on very large image sequences. A set of experimental data shows the use of such framework for processing Advanced Very High Resolution Radiometer (AVHRR) and Coastal Zone Color Scanner (CZCS) image sequences
https://hal.inria.fr/inria-00532681 Contributor : Brigitte BriotConnect in order to contact the contributor Submitted on : Wednesday, April 20, 2016 - 4:54:09 PM Last modification on : Thursday, February 3, 2022 - 11:18:57 AM Long-term archiving on: : Tuesday, November 15, 2016 - 7:23:04 AM
Isabelle Herlin, Isaac Cohen, Sonia Bouzidi. Detection and Tracking of Vortices on Oceanographic Images. Proceedings of Scandinavian Conference on Image Analysis, Jun 1995, Uppsala, Sweden. pp.689-696. ⟨inria-00532681⟩
