Segmentation of Temporal Effects on Phasimetric SAR Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Presents a segmentation method to detect effects due to high temporal evolution of the interferometric phase. The segmentation of these phasimetric artefacts is performed, taking into consideration both phase image and interferometric correlation. The process is based on a statistical model, robust in a noisy environment. It is expressed in a Markovian random field framework. This work is particularly original in respect to its application domain. The major novelty of the approach resides on the use of two pieces of information in order to correspond exactly to the effects definition. It is used to segment phasimetric effects, appearing on some kind of ground occupation, due to rainy events
Fichier non déposé
inria-00532717 , version 1 (04-11-2010)
Etienne Huot, Isabelle Herlin, Dominique Béréziat. Segmentation of Temporal Effects on Phasimetric SAR Images. Proceedings of the International Conference on Pattern Recognition, IAPR, 1998, Brisbane, Australia. pp.1390-1392, ⟨10.1109/ICPR.1998.711962⟩. ⟨inria-00532717⟩
Collections
INRIA INRIA2
42 Consultations
0 Téléchargements
