Conference papers
Curves Matching Using Geodesic Paths
Abstract : We present a method for matching curves which accommodates large and small deformation. The method preserves geometric similarities in the case of small deformation, and loosens these geometric constraints when large deformations occur. The approach is based on the computation of a set of geodesic paths connecting the curves. These two curves are defined as a source area and a destination area which can have an arbitrary number of connected components and different topologies. The applicative framework of the presented method is the study of the crustal deformation from a set of iso-elevation curves. An experiment with real curves demonstrates that the approach can be successfully applied to characterize deformation of Digital Elevation Models.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00532724
Contributor : Brigitte Briot Connect in order to contact the contributor
Submitted on : Wednesday, April 20, 2016 - 12:10:51 PM
Last modification on : Thursday, February 3, 2022 - 11:16:27 AM
Long-term archiving on: : Tuesday, November 15, 2016 - 7:00:17 AM
File
Cohen-CVPR-1998.pdf
Identifiers
  • HAL Id : inria-00532724, version 1
Collections
Citation
Isaac Cohen, Isabelle Herlin. Curves Matching Using Geodesic Paths. Proceedings of the conference on Computer Vision and Pattern Recognition, IEEE, Jun 1998, Santa-Barbara, United States. pp.741-746. ⟨inria-00532724⟩
Share
Metrics
Record views
54
Files downloads
131
