Reduction of chemical kinetics in air pollution modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2000
We investigate in this article the use of reduction techniques in air pollution modeling. The reduction of chemical kinetics is performed on the basis of a timescale analysis and of lumping. Lumping techniques are widely used in air pollution modeling and consist of replacing some pure chemical species by linear combinations of species. We focus here on the theoretical justification of such techniques. We propose an algorithm in order to build up lumped species in a systematic way. An application to three kinetic schemes coupled with diffusion is presented in a monodimensional case. This justifies the way we couple a reduced kinetic scheme with other processes.
inria-00532736 , version 1 (04-11-2010)
Bruno Sportisse, Rafik Djouad. Reduction of chemical kinetics in air pollution modelling. Journal of Computational Physics, 2000, 164 (2), pp.354-376. ⟨10.1006/jcph.2000.6601⟩. ⟨inria-00532736⟩
Collections
INRIA INRIA2
70 Consultations
0 Téléchargements
