New interface
Conference papers
Sensitivity analysis of GreenLab model for maize
Qiongli Wu 1, 2, * Paul-Henry Cournède 1, 2
* Corresponding author
2 DIGIPLANTE - Modélisation de la croissance et de l'architecture des plantes
MAS - Mathématiques Appliquées aux Systèmes - EA 4037, Cirad - Centre de Coopération Internationale en Recherche Agronomique pour le Développement, Inria Saclay - Ile de France
Abstract : As one necessary step for a good modeling, this study was aimed at analyzing the sensitivity of GreenLab model for maize. When instantaneous value of biomass generation is considered as the output, the system tends to be linear, the level is above 94% in SRC(Standardized Regression coefficients)study. Conversion efficiency and characteristic surface are proved to be the most sensitive factors. In Sobol's measure, we excluded the two most sensitive factors in the analysis, then the system linearity tends to be weaker and we got the detailed sensitivity indexes for the other uncertain parameters, by which we get the clearer driven force of maize growth in different stages.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/inria-00532950
Contributor : Qiongli Wu Connect in order to contact the contributor
Submitted on : Thursday, November 4, 2010 - 6:35:14 PM
Last modification on : Friday, February 4, 2022 - 3:34:38 AM
Long-term archiving on: : Saturday, February 5, 2011 - 3:07:24 AM
File
WU_04072009.pdf
Identifiers
  • HAL Id : inria-00532950, version 1
Collections
Citation
Qiongli Wu, Paul-Henry Cournède. Sensitivity analysis of GreenLab model for maize. 3rd international symposium on Plant Growth and Applications (PMA09), Nov 2010, Beijing, China. ⟨inria-00532950⟩
Share
Metrics
Record views
179
Files downloads
180
