Assessing and Re-Modularizing Object- Oriented Architectural Elements, 2009. ,
URL : https://hal.archives-ouvertes.fr/tel-00498389
A comprehensive empirical validation of design measures for object-oriented systems, Proceedings Fifth International Software Metrics Symposium. Metrics (Cat. No.98TB100262), pp.246-257, 1998. ,
DOI : 10.1109/METRIC.1998.731251
A Unified Framework for Cohesion Measurement in Object-Oriented Systems. Empirical Software Engineering, An International Journal, vol.3, issue.1, pp.65-117, 1998. ,
A unified framework for coupling measurement in object-oriented systems, IEEE Transactions on Software Engineering, vol.25, issue.1, pp.91-121, 1999. ,
DOI : 10.1109/32.748920
Toward the design quality evaluation of object-oriented software systems, Proc. 5th Int'l Conf. Software Quality, pp.44-57, 1995. ,
Cohesion and reuse in an object-oriented system, Proceedings ACM Symposium on Software Reusability, 1995. ,
Property-based software engineering measurement, IEEE Transactions on Software Engineering, vol.22, issue.1, pp.68-86, 1996. ,
DOI : 10.1109/32.481535
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.25
A metrics suite for object oriented design, IEEE Transactions on Software Engineering, vol.20, issue.6, pp.476-493, 1994. ,
Software Metrics: A Rigorous and Practical Approach, 1996. ,
DOI : 10.1201/b17461
Empirical validation of object-oriented metrics on open source software for fault prediction, IEEE Transactions on Software Engineering, vol.31, issue.10, pp.31897-910, 2005. ,
DOI : 10.1109/TSE.2005.112
Data Mining, 2000. ,
DOI : 10.1007/978-1-4899-7993-3_104-2
Measuring product attributes of object-oriented systems, Proc. ESEC '95 (5th European Software Engineering Conference, pp.124-136, 1995. ,
DOI : 10.1007/3-540-60406-5_11
Object-Oriented Metrics: Measures of Complexity, 1996. ,
Metrics and Models in Software Quality Engineering ,
Object-oriented metrics that predict maintainability, Journal of Systems and Software, vol.23, issue.2, pp.111-122, 1993. ,
DOI : 10.1016/0164-1212(93)90077-B
Object-Oriented Software Metrics: A Practical Guide, 1994. ,
Object-Oriented Metrics in Practice, 2006. ,
Design principles and design patterns ,
The tipping point: Stability and instability in oo design, 2005. ,
Only connect. an investigation into the relationship between object-oriented design metrics and the hacking culture, 1999. ,
A Complexity Measure, IEEE Transactions on Software Engineering, vol.2, issue.4, pp.308-320, 1976. ,
DOI : 10.1109/TSE.1976.233837
Cohesion is structural, coherence is functional: Different views, different measures, Proceedings of the Seventh International Software Metrics Symposium (METRICS-01, 2001. ,
Quantifying the quality of objectoriented design: the factor-strategy model, Proceedings 11th Working Conference on Reverse Engineering, pp.192-201, 2004. ,
Exploiting Client Usage to Manage Program Modularity, 2006. ,
Structured design, IBM Systems Journal, vol.13, issue.2, pp.115-139, 1974. ,
DOI : 10.1147/sj.132.0115
How Do Java Programs Use Inheritance? An Empirical Study of Inheritance in Java Software, ECOOP '08: Proceedings of the 22nd European conference on Object-Oriented Programming, pp.667-691, 2008. ,
DOI : 10.1007/978-3-540-70592-5_28
