New interface
Conference papers
Joint Optimization of Monitor Location and Network Anomaly Detection
Emna Salhi 1 Samer Lahoud 1 Bernard Cousin 1
1 ATNET - Advanced Technolgy in Networking
IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
Abstract : Achieving cost-effective systems for network performance monitoring has been the subject of many research works over the last few years. Most of them adopt a two-step approach. The first step assigns optimal locations to monitors, whereas the second step selects a minimal set of paths to be monitored. However, such an approach does not consider the trade-off between the optimization objectives of each step, and hence may lead to sub-optimal usage of network resources and biased measurements. In this paper, we propose to evaluate and reduce this trade-off. Toward this end, we come up with two ILP formulations for a novel monitoring cost model that apply for both passive and active monitoring. The aim is to minimize the monitor location cost and the anomaly detection cost jointly, thereby obtaining a monitoring solution that minimizes the total monitoring cost. Simulation results illustrate the interplay between the optimization objectives and evaluate the quality of the obtained monitoring solution.
Document type :
Conference papers
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/inria-00534365
Contributor : Emna Salhi Connect in order to contact the contributor
Submitted on : Tuesday, November 9, 2010 - 2:29:14 PM
Last modification on : Tuesday, October 19, 2021 - 11:58:54 PM
Long-term archiving on: : Thursday, February 10, 2011 - 2:48:36 AM
File
paper.pdf
Identifiers
  • HAL Id : inria-00534365, version 1
Citation
Emna Salhi, Samer Lahoud, Bernard Cousin. Joint Optimization of Monitor Location and Network Anomaly Detection. IEEE LCN, Oct 2010, Denver, Colorado, United States. ⟨inria-00534365⟩
Share
Metrics
Record views
438
Files downloads
613
