Integer Affine Transformations of Parametric Z-polytopes and Applications to Loop Nest Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The polyhedral model is a well-known compiler optimization framework for the analysis and transformation of affine loop nests. We present a new method concerning a difficult geometric operation that is raised by this model: the integer affine transformation of parametric Z-polytopes. The result of such a transformation is given by a worst-case exponential union of Z-polytopes. We also propose a polynomial algorithm (for fixed dimension), to count points in arbitrary unions of a fixed number of parametric Z-polytopes. We implemented these algorithms and compared them to other existing algorithms, for a set of applications to loop nest analysis and optimization.
rapport.pdf (262.99 Ko) Télécharger le fichier
inria-00534686 , version 1 (10-11-2010)
  • HAL Id : inria-00534686 , version 1
Rachid Seghir, Vincent Loechner, Benoit Meister. Integer Affine Transformations of Parametric Z-polytopes and Applications to Loop Nest Optimization. [Research Report] 2010, pp.30. ⟨inria-00534686⟩
178 Consultations
358 Téléchargements
