Volume Computation for Polytopes and Partition Functions for Classical Root Systems, Discrete & Computational Geometry, vol.35, issue.4, pp.551-595, 2006. ,
DOI : 10.1007/s00454-006-1234-2
Computing the Ehrhart polynomial of a convex lattice polytope, Discrete & Computational Geometry, vol.295, issue.2, pp.35-48, 1994. ,
DOI : 10.1007/BF02574364
Short rational generating functions for lattice point problems, Journal of the American Mathematical Society, vol.16, pp.657-979, 2003. ,
A Polynomial Time Algorithm for Counting Integral Points in Polyhedra When the Dimension is Fixed, Mathematics of Operations Research, vol.19, issue.4, pp.769-779, 1994. ,
DOI : 10.1287/moor.19.4.769
Counting the solutions of Presburger equations without enumerating them, Theoretical Computer Science, vol.313, issue.1, pp.17-29, 2004. ,
DOI : 10.1016/j.tcs.2003.10.002
Communication pre-evaluation in HPF, EUROPAR'98, pp.263-272, 1998. ,
DOI : 10.1007/BFb0057861
URL : https://hal.archives-ouvertes.fr/inria-00565190
Parametric analysis of polyhedral iteration spaces, Proceedings of International Conference on Application Specific Systems, Architectures and Processors: ASAP '96, pp.179-194, 1998. ,
DOI : 10.1109/ASAP.1996.542833
URL : https://hal.archives-ouvertes.fr/inria-00534840
Static analysis of parameterized loop nests for energy efficient use of data caches, Workshop on Compilers and Operating Systems for Low Power (COLP01), 2001. ,
Fourier-Motzkin elimination and its dual, J. Comb. Theory, Ser. A, vol.14, issue.3, pp.288-297, 1973. ,
Effective lattice point counting in rational convex polytopes, Journal of Symbolic Computation, vol.38, issue.4, pp.1273-1302, 2004. ,
Polynômes arithmétiques et méthode des polyèdres en combinatoire, International Series of Numerical Mathematics, vol.35, 1977. ,
Solving systems of affine (in)equalities, 2002. ,
Parametric integer programming, RAIRO - Operations Research, vol.22, issue.3, pp.243-268, 1988. ,
DOI : 10.1051/ro/1988220302431
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.9957
Cache miss equations: a compiler framework for analyzing and tuning memory behavior, ACM Transactions on Programming Languages and Systems, vol.21, issue.4, pp.703-746, 1999. ,
DOI : 10.1145/325478.325479
Volume driven data distribution for NUMAmachines, Proceedings from the 6th International Euro-Par Conference on Parallel Processing, pp.415-424, 2000. ,
The Omega Library, 1996. ,
An implementation of the barvinok?woods integer projection algorithm, ITSL, pp.53-59, 2008. ,
Elements of Mathematical Logic. The Netherlands, 1967. ,
Weak quantifier elimination for the full linear theory of the integers, Applicable Algebra in Engineering, Communication and Computing, vol.8, issue.2, pp.545-574, 2007. ,
DOI : 10.1007/s00200-007-0053-x
Polylib: A library for manipulating parameterized polyhedra, 1999. ,
Precise data locality optimization of nested loops, The Journal of Supercomputing, vol.21, issue.1, pp.37-76, 2002. ,
DOI : 10.1023/A:1013535431127
URL : https://hal.archives-ouvertes.fr/inria-00534831
Projecting periodic polyhedra for loop nest analysis, Proceedings of the 11th Workshop on Compilers for Parallel Computers (CPC 04), Kloster Seeon, pp.13-24, 2004. ,
A library for Z-polyhedral operations, 1330. ,
An Automata-Theoretic Algorithm for Counting Solutions to Presburger Formulas, Compiler Construction, pp.104-119, 2004. ,
DOI : 10.1007/978-3-540-24723-4_8
The Omega test: a fast and practical integer programming algorithm for dependence analysis, Proceedings of the 1991 ACM/IEEE conference on Supercomputing , Supercomputing '91, pp.4-13, 1991. ,
DOI : 10.1145/125826.125848
Counting solutions to Presburger formulas: how and why, SIGPLAN Conference on Programming Language Design and Implementation (PLDI'94), pp.121-134, 1994. ,
Experiences with constraint-based array dependence analysis, Principles and Practice of Constraint Programming, pp.312-325, 1994. ,
DOI : 10.1007/3-540-58601-6_109
On Manipulating Z-Polyhedra Using a Canonical Representation, Parallel Processing Letters, vol.07, issue.02, pp.181-194, 1997. ,
DOI : 10.1142/S012962649700019X
Reducing memory requirements of nested loops for embedded systems, Proceedings of the 38th conference on Design automation , DAC '01, pp.359-364, 2001. ,
DOI : 10.1145/378239.378523
Theory of linear and integer programming, 1986. ,
Memory optimization by counting points in integer transformations of parametric polytopes, Proceedings of the 2006 international conference on Compilers, architecture and synthesis for embedded systems , CASES '06, pp.74-82, 2006. ,
DOI : 10.1145/1176760.1176771
Solving Out-of-Order Communication in Kahn Process Networks, Journal of VLSI signal processing systems for signal, image and video technology, vol.14, issue.3, pp.7-18, 2005. ,
DOI : 10.1007/s11265-005-4935-5
Barvinok: user guide, 2006. ,
Experiences with Enumeration of Integer Projections of Parametric Polytopes, Compiler Construction: 14th International Conference, pp.91-105, 2005. ,
DOI : 10.1007/978-3-540-31985-6_7
Analytical computation of Ehrhart polynomials, Proceedings of the 2004 international conference on Compilers, architecture, and synthesis for embedded systems , CASES '04, pp.248-258, 2004. ,
DOI : 10.1145/1023833.1023868
Counting Integer Points in Parametric Polytopes Using Barvinok's Rational Functions, Algorithmica, vol.48, issue.1, pp.37-66, 2007. ,
DOI : 10.1007/s00453-006-1231-0
Counting with rational generating functions, Journal of Symbolic Computation, vol.43, issue.2, p.504059, 2005. ,
DOI : 10.1016/j.jsc.2007.07.007
Exact memory size estimation for array computations, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, pp.517-521, 2000. ,
Memory Size Computation for Real-Time Multimedia Applications Based on Polyhedral Decomposition, IEICE Transactions on Fundamentals of Electronics, Communications and Computer Sciences, vol.89, issue.12, pp.89-3378, 2006. ,
DOI : 10.1093/ietfec/e89-a.12.3378
