Finite volume schemes for constrained conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2010
This paper is devoted to the numerical analysis of the road traffic model proposed by Colombo and Goatin in [CG07]. The model involves a standard conservation law supplemented by a local unilateral constraint on the flux at the point x = 0 (modelling a road light, a toll gate, etc.). We first show that the problem can be interpreted in terms of the the- ory of conservation laws with discontinuous flux function, as developed by Adimurthi et al. [AMG05] and Bu ̈rger et al. [BKT09]. We reformulate accordingly the notion of entropy solution introduced in [CG07], and ex- tend the well-posedness results to the L∞ framework. Then, starting from a general monotone finite volume scheme for the non-constrained conser- vation law, we produce a simple scheme for the constrained problem and show its convergence. The proof uses a new notion of entropy process solution. Numerical examples modelling a “green wave” are presented.
AGS-preprint.pdf (557.38 Ko) Télécharger le fichier
inria-00534872 , version 1 (10-11-2010)
  • HAL Id : inria-00534872 , version 1
Paola Goatin, Nicolas Seguin, Boris Andreianov. Finite volume schemes for constrained conservation laws. Numerische Mathematik, 2010, 115 (4), pp.609-645. ⟨inria-00534872⟩
335 Consultations
182 Téléchargements
