Impact of job dropping on the schedulability of uniprocessor probabilistic real-time systems with variable execution times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Buffet
Liliana Cucu-Grosjean
  • Fonction : Auteur
  • PersonId : 844766
In this paper we address the problem of uniprocessor probabilistic scheduling of real-time systems with variable execution times. For these systems the tasks have an associated probability of missing the deadline, i.e., some jobs may miss their deadlines without affecting the schedulability of the system. Therefore dropping these jobs does not affect the schedulability of the system and it could increase the probability of other jobs to meet their deadline. The problem of deciding what jobs to drop is not trivial and we discuss a possible solution.
rtsops10.pdf (60.31 Ko) Télécharger le fichier
inria-00535561 , version 1 (11-11-2010)
  • HAL Id : inria-00535561 , version 1
Olivier Buffet, Liliana Cucu-Grosjean. Impact of job dropping on the schedulability of uniprocessor probabilistic real-time systems with variable execution times. 1st International Real-Time Scheduling Open Problems Seminar : RTSOPS 2010, Jul 2010, Bruxelles, Belgium. ⟨inria-00535561⟩
112 Consultations
67 Téléchargements
