Syntactic testsuites and Textual Entailment Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We focus on textual entailments mediated by syntax and propose a new methodology to evaluate textual entailment recognition systems on such data. The main idea is to generate a syntactically annotated corpus of pairs of (non-)entailments and to use error mining to identify the most likely sources of errors. To illustrate the approach, we apply this methodology to the Afazio RTE system and show how it permits identifying the most likely sources of errors made by this system on a testsuite of 10 000 (non) entailment pairs.
lrec10-bedgar.pdf (73.38 Ko) Télécharger le fichier
inria-00536020 , version 1 (15-11-2010)
  • HAL Id : inria-00536020 , version 1
Paul Bedaride, Claire Gardent. Syntactic testsuites and Textual Entailment Recognition. The seventh International Conference on Language Resources and Evaluation - LREC 2010, May 2010, Valletta, Malta. ⟨inria-00536020⟩
231 Consultations
59 Téléchargements
