Quantifying the Sub-optimality of Uniprocessor Fixed Priority Non-Pre-emptive Scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper examines the relative effectiveness of fixed priority non-pre-emptive scheduling (FP-NP) in a uniprocessor system, compared to an optimal work-conserving non-pre-emptive algorithm; Earliest Deadline First (EDF-NP). The quantitative metric used in this comparison is the processor speedup factor, defined as the factor by which processor speed needs to increase to ensure that any taskset that is schedulable according to EDF-NP can be scheduled using FP-NP scheduling. For sporadic tasksets with implicit, constrained, or arbitrary deadlines, the speedup factor is shown to be lower bounded by 1/Omega (1.76322) and upper bounded by 2. We also report the results of empirical investigations into the speedup factor required to ensure schedulability in the non-pre-emptive case.
rtns2010_davis.pdf (290.25 Ko) Télécharger le fichier
inria-00536363 , version 1 (16-11-2010)
  • HAL Id : inria-00536363 , version 1
Robert Davis, Laurent George, Pierre Courbin. Quantifying the Sub-optimality of Uniprocessor Fixed Priority Non-Pre-emptive Scheduling. 18th International Conference on Real-Time and Network Systems, Nov 2010, Toulouse, France. pp.1-10. ⟨inria-00536363⟩
516 Consultations
196 Téléchargements
