ESBTL: efficient PDB parser and data structure for the structural and geometric analysis of biological macromolecules. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2010
The ever increasing number of structural biological data calls for robust and efficient software for analysis. Easy Structural Biology Template Library (ESBTL) is a lightweight C++ library that allows the handling of PDB data and provides a data structure suitable for geometric constructions and analyses. The parser and data model provided by this ready-to-use include-only library allows adequate treatment of usually discarded information (insertion code, atom occupancy, etc.) while still being able to detect badly formatted files. The template-based structure allows rapid design of new computational structural biology applications and is fully compatible with the new remediated PDB archive format. It also allows the code to be easy-to-use while being versatile enough to allow advanced user developments. AVAILABILITY: ESBTL is freely available under the GNU General Public License from http://esbtl.sf.net. The web site provides the source code, examples, code snippets and documentation.
inria-00536404 , version 1 (16-11-2010)
Sébastien Loriot, Frédéric Cazals, Julie Bernauer. ESBTL: efficient PDB parser and data structure for the structural and geometric analysis of biological macromolecules.. Bioinformatics, 2010, 26 (8), pp.1127-8. ⟨10.1093/bioinformatics/btq083⟩. ⟨inria-00536404⟩
258 Consultations
0 Téléchargements
