The structural alignment between two proteins: Is there a unique answer?, Protein Science, vol.221, issue.7, pp.1325-1338, 1996. ,
DOI : 10.1002/pro.5560050711
D??j?? Vu All Over Again, Structure, vol.12, issue.12, pp.2103-2111, 2004. ,
DOI : 10.1016/j.str.2004.09.016
An efficient branch-and-bound algorithm for finding a maximum clique, Discrete Mathematics and Theoretical Computer Science, vol.58, p.220, 2003. ,
An improved branch and bound algorithm for the maximum clique problem, Communications in Mathematical and in Computer Chemistry / MATCH, vol.58, pp.569-590, 2007. ,
A fast algorithm for the maximum clique problem, Discrete Applied Mathematics, vol.120, issue.1-3, pp.197-207, 2002. ,
DOI : 10.1016/S0166-218X(01)00290-6
Data growth and its impact on the SCOP database: new developments, Nucleic Acids Research, vol.36, issue.Database, pp.419-425, 2007. ,
DOI : 10.1093/nar/gkm993
Optimal Protein Structure Alignment Using Maximum Cliques, Operations Research, vol.53, issue.3, pp.389-402, 2005. ,
DOI : 10.1287/opre.1040.0189
Reducibility among combinatorial problems, Complexity of Computer Computations, vol.6, pp.85-103, 1972. ,
The Maximum Clique Problem, Handbook of Combinatorial Optimization, 1999. ,
DOI : 10.1007/978-1-4757-3023-4_1
Surprising similarities in structure comparison, Current Opinion in Structural Biology, vol.6, issue.3, pp.377-385, 1996. ,
DOI : 10.1016/S0959-440X(96)80058-3
Flexible algorithm for direct multiple alignment of protein structures and sequences, Bioinformatics, vol.10, issue.6, pp.587-596, 1994. ,
DOI : 10.1093/bioinformatics/10.6.587
An Efficient Lagrangian Relaxation for the Contact Map Overlap Problem, WABI '08: Proceedings of the 8th international workshop on Algorithms in Bioinformatics, pp.162-173, 2008. ,
DOI : 10.1007/978-3-540-87361-7_14
URL : https://hal.archives-ouvertes.fr/inria-00327135
1001 Optimal PDB Structure Alignments: Integer Programming Methods for Finding the Maximum Contact Map Overlap, Journal of Computational Biology, vol.11, issue.1, pp.27-52, 2004. ,
DOI : 10.1089/106652704773416876
On computing the length of longest increasing subsequences, Discrete Mathematics, vol.11, issue.1, pp.29-35, 1975. ,
DOI : 10.1016/0012-365X(75)90103-X
Protein secondary structure assignment revisited: a detailed analysis of different assignment methods, BMC Structural Biology, vol.5, issue.1, p.17, 2005. ,
DOI : 10.1186/1472-6807-5-17
URL : https://hal.archives-ouvertes.fr/inserm-00090199
101 optimal PDB structure alignments, Proceedings of the fifth annual international conference on Computational biology , RECOMB '01, pp.193-202, 2001. ,
DOI : 10.1145/369133.369199
Likelihood linkage analysis (LLA) classification method: An example treated by hand, Biochimie, vol.75, issue.5, pp.379-397, 1993. ,
DOI : 10.1016/0300-9084(93)90172-O
