Conference papers
Ordering Constraints over Feature Trees Expressed in Second-order Monadic Logic
Abstract : The system FT< of ordering constraints over feature trees has been introduced as an extension of the system FT of equality constraints over feature trees. We investigate decidability and complexity questions for fragments of the first-order theory of FT<. It is well-known that the first-order theory of FT< is decidable and that several of its fragments can be decided in quasi-linear time, including the satisfiability problem of FT< and its entailment problem with existential quantification p |= models E x1 ... E xn p' Much less is known on the first-order theory of FT<. The satisfiability problem of FT< can be decided in cubic time, as well as its entailment problem without existential quantification. Our main result is that the entailment problem of FT< with existential quantifiers is decidable but PSPACE-hard. Our decidability proof is based on a new technique where feature constraints are expressed in second-order monadic logic with countably many successors SwS. We thereby reduce the entailment problem of FT< with existential quantification to Rabin's famous theorem on tree automata.
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/inria-00536814
Contributor : Joachim Niehren Connect in order to contact the contributor
Submitted on : Tuesday, November 16, 2010 - 11:09:54 PM
Last modification on : Tuesday, October 31, 2017 - 2:22:18 PM
Long-term archiving on: : Thursday, February 17, 2011 - 3:15:58 AM
SWSJournal99.pdf
Identifiers
  • HAL Id : inria-00536814, version 1
Citation
Martin Müller, Joachim Niehren. Ordering Constraints over Feature Trees Expressed in Second-order Monadic Logic. 9th International Conference on Rewriting Techniques and Applications, 1998, Tsukuba, Japan. pp.196--210. ⟨inria-00536814⟩
Share
Metrics
Record views
17
Files downloads
88
