RTG based surface realisation for TAG - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Surface realisation with grammars integrating flat semantics is known to be NP complete. In this paper, we present a new algorithm for surface realisation based on Feature Based Tree Adjoining Grammar (FTAG) which draws on the observation that an FTAG can be translated into a Regular Tree Grammar describing its derivation trees. We carry out an extensive testing of several variants of this algorithm using an automatically produced testsuite and compare the results obtained with those obtained using GenI, another FTAG based surface realiser.
garper-coling10.pdf (89.73 Ko) Télécharger le fichier
inria-00537159 , version 1 (19-11-2010)
inria-00537159 , version 2 (11-03-2011)
  • HAL Id : inria-00537159 , version 2
Claire Gardent, Laura Perez-Beltrachini. RTG based surface realisation for TAG. 23rd International Conference on Computational Linguistics - Coling 2010, Aug 2010, Beijing, China. pp.367--375. ⟨inria-00537159v2⟩
140 Consultations
116 Téléchargements
