Let ? = ? 1 x 1 . . . ? n x n ?(x 1 . . . x n ) be an instance of REFERENCES Arenas Consistent query answers in inconsistent databases, Proceedings of PODS, 1973. ,
Properties of acyclic database schemes, Proceedings of the thirteenth annual ACM symposium on Theory of computing , STOC '81, 1981. ,
DOI : 10.1145/800076.802489
Applying model management to classical meta data, Proceedings of CIDR, 2003. ,
Using Semi-Joins to Solve Relational Queries, Journal of the ACM, vol.28, issue.1, pp.25-40, 1981. ,
DOI : 10.1145/322234.322238
Optimal implementation of conjunctive queries in relational data bases, Proceedings of the ninth annual ACM symposium on Theory of computing , STOC '77, 1977. ,
DOI : 10.1145/800105.803397
RoadRunner, Proceedings of the 2002 ACM SIGMOD international conference on Management of data , SIGMOD '02, 2001. ,
DOI : 10.1145/564691.564778
The Recursive Unsolvability of the Decision Problem for the Class of Definite Formulas, Journal of the ACM, vol.16, issue.2, pp.324-327, 1969. ,
DOI : 10.1145/321510.321524
Graph Theory, 2005. ,
Data exchange: Semantics and query answering, Proceedings of ICDT, 2003. ,
DOI : 10.1016/j.tcs.2004.10.033
URL : http://doi.org/10.1016/j.tcs.2004.10.033
Quasi-inverses of schema mapping, Proceedings of PODS, 2007. ,
Composing schema mappings: Second-order dependencies to the rescue, Proceedings of PODS, 2004. ,
On the data mapping problem, 2007. ,
Computers And Intractability. A Guide to the Theory of NP-completeness, 1979. ,
On the complexity of some inductive logic programming problems, Proceedings of ILP, 1997. ,
Hypertree decompositions and tractable queries, Proceedings of PODS, 1999. ,
DOI : 10.1145/303976.303979
URL : http://arxiv.org/abs/cs/9812022
Clio grows up, Proceedings of the 2005 ACM SIGMOD international conference on Management of data , SIGMOD '05, pp.805-810, 2005. ,
DOI : 10.1145/1066157.1066252
Reducing the Size of NFAs by Using Equivalences and Preorders, Combinatorial Pattern Matching, 2002. ,
DOI : 10.1007/11496656_27
Schema mappings, data exchange, and metadata management, Proceedings of the twenty-fourth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '05, 2005. ,
DOI : 10.1145/1065167.1065176
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.102.3663
Theorie der endlichen und unendlichen Graphen, 1936. ,
Inductive Logic Programming: Techniques and Applications, 1994. ,
DOI : 10.1007/3-540-63514-9
Data integration, Proceedings of the twenty-first ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '02, 2002. ,
DOI : 10.1145/543613.543644
An Introduction to Kolmogorov Complexity and Its Applications, second ed, 1997. ,
Computational Complexity, 1994. ,
A survey of approaches to automatic schema matching, The VLDB Journal, vol.10, issue.4, pp.334-350, 2001. ,
DOI : 10.1007/s007780100057
Completeness in the polynomial hierarchy, a compendium, SIGACT News, vol.33, issue.3, pp.32-49, 2002. ,
On the complexity of deriving schema mappings from database instances, Proceedings of the twenty-seventh ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '08, pp.23-32, 2008. ,
DOI : 10.1145/1376916.1376921
Word problems requiring exponential time, Proceedings of STOC, 1973. ,
DOI : 10.1145/800125.804029
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.116.4618
Simple Linear-Time Algorithms to Test Chordality of Graphs, Test Acyclicity of Hypergraphs, and Selectively Reduce Acyclic Hypergraphs, SIAM Journal on Computing, vol.13, issue.3, pp.566-579, 1984. ,
DOI : 10.1137/0213035
Impossibility of an algorithm for the decision problem in finite classes, pp.1-5, 1963. ,
Complete sets and the polynomial-time hierarchy, Theoretical Computer Science, vol.3, issue.1, pp.23-33, 1976. ,
DOI : 10.1016/0304-3975(76)90062-1
Algorithms for acyclic database schemes, Proceedings of VLDB. VLDB Endowment, 1981. ,
