A suitable computational strategy for the parametric analysis of problems with multiple contact, International Journal for Numerical Methods in Engineering, vol.1, issue.9, pp.1259-1282, 2003. ,
DOI : 10.1002/nme.724
Approche multir??solution pour l'??tude param??trique d'assemblages par contact et frottement, Revue Europ??enne des ??l??ments Finis, vol.5, issue.3, pp.437-448, 2004. ,
DOI : 10.3166/reef.13.437-448
Une strat??gie multi-??chelle pour l'??tude param??trique de d??tails g??om??triques au sein de structures en contacts multiples, Revue Européenne de Mécanique Numérique, pp.1011-1036, 2007. ,
DOI : 10.3166/remn.16.1001-1036
Accelerating Evolutionary Algorithms With Gaussian Process Fitness Function Models, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.35, issue.2, 2005. ,
DOI : 10.1109/TSMCC.2004.841917
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.4.3353
Multilevel decomposition procedure for efficient design optimization of helicopter rotor blades, AIAA Journal, vol.33, issue.2, pp.223-230, 1995. ,
DOI : 10.2514/3.12424
Large scale applications on parallel computers of a mixed domain decomposition method, Computational Mechanics, vol.19, issue.4, pp.253-263, 1997. ,
DOI : 10.1007/s004660050174
URL : https://hal.archives-ouvertes.fr/hal-00321318
Modular analysis of assemblages of threedimensional structures with unilateral contact conditions, Computers and Structures, vol.73, pp.4249-266, 1999. ,
Multidisciplinary design optimization of mechanisms, Advances in engineering software, pp.301-311, 2005. ,
DOI : 10.1016/j.advengsoft.2004.10.013
Compressible flow solvers using unstructured grids, 1992. ,
URL : https://hal.archives-ouvertes.fr/inria-00076971
Multi-level parameterization for shape optimization in aerodynamics and electromagnetics using particle swarm optimization, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00109722
Optimum structural design with parallel finite element analysis, Compututers and Structures, vol.91, issue.40 6, pp.1469-1474, 1991. ,
Single- and multiobjective evolutionary optimization assisted by Gaussian random field metamodels, IEEE Transactions on Evolutionary Computation, vol.10, issue.4, pp.421-439, 2006. ,
DOI : 10.1109/TEVC.2005.859463
Implementation of a multi-level optimisation methodology within the e-design of a blended wing body, Aerospace Science and Technology, vol.8, issue.2, pp.145-153, 2004. ,
DOI : 10.1016/j.ast.2003.10.001
Curves and surfaces for computer-aided geometric design, 1989. ,
The particle swarm optimization algorithm in size and shape optimization, Structural and Multidisciplinary Optimization, vol.23, issue.4, 2002. ,
DOI : 10.1007/s00158-002-0188-0
Design of optimal aerodynamic shapes using stochastic optimization methods and computational intelligence, Progress in Aerospace Sciences, vol.38, issue.1, pp.43-76, 2002. ,
DOI : 10.1016/S0376-0421(01)00019-7
Une approche micro-macro pour le suivi de fissure avec enrichissement local, Revue Européenne de Mécanique Numérique, pp.187-198, 2006. ,
DOI : 10.3166/remn.15.187-198
URL : https://hal.archives-ouvertes.fr/hal-00091765
A comprehensive survey of fitness approximation in evolutionary computation, Soft Computing, vol.9, issue.1, 2005. ,
DOI : 10.1007/s00500-003-0328-5
Aircraft wing design using GA-based multi-level strategies, 8th Symposium on Multidisciplinary Analysis and Optimization, pp.0-40, 2000. ,
DOI : 10.2514/6.2000-4937
Particle swarm optimization, Proceedings of ICNN'95, International Conference on Neural Networks, 1995. ,
DOI : 10.1109/ICNN.1995.488968
Multi-resolution multi-scale topology optimization ??? a new paradigm, International Journal of Solids and Structures, vol.37, issue.39, pp.5529-5559, 2000. ,
DOI : 10.1016/S0020-7683(99)00251-6
Efficient multilevel MINLP strategies for solving large combinatorial problems in engineering, Optimization and Engineering, vol.4, issue.1/2, pp.97-151, 2003. ,
DOI : 10.1023/A:1021812414215
The multilevel MINLP optimization approach to structural synthesis: the simultaneous topology, material, standard and rounded dimension optimization, Advances in engineering software, pp.568-583, 2005. ,
DOI : 10.1016/j.advengsoft.2005.03.004
Nonlinear Computational Structural Mechanics -New Approaches and non-Incremental Methods of Calculation, 1999. ,
A micro???macro and parallel computational strategy for highly heterogeneous structures, International Journal for Numerical Methods in Engineering, vol.46, issue.12, pp.121-138, 2001. ,
DOI : 10.1002/nme.274
A multiscale computational approach for contact problems, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.43, pp.4680-4891, 2002. ,
DOI : 10.1016/S0045-7825(02)00406-1
On a multiscale computational strategy with time and space homogenization for structural mechanics, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.28-30, pp.3061-3088, 2003. ,
DOI : 10.1016/S0045-7825(03)00341-4
Design of dimensionally stable composites by evolutionary optimization, Composite Structures, vol.41, issue.2, pp.97-111, 1998. ,
DOI : 10.1016/S0263-8223(98)00009-9
An evolutionary shape optimization for elastic contact problems subject to multiple load cases, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.30-33, pp.3394-3415, 2005. ,
DOI : 10.1016/j.cma.2004.12.024
Global-local structural optimization using response surfaces of local optimization margins, Structural and Multidisciplinary Optimization, vol.27, issue.5, pp.352-359, 2004. ,
DOI : 10.1007/s00158-004-0393-0
A finite element method for crack growth without remeshing, International Journal for Numerical Methods in Engineering, vol.46, issue.1, pp.131-150, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990910)46:1<131::AID-NME726>3.3.CO;2-A
Surrogate-Assisted Evolutionary Optimization Frameworks for High-Fidelity Engineering Design Problems, Studies in Fuzziness and Soft Computing, 2004. ,
DOI : 10.1007/978-3-540-44511-1_15
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, pp.12-49, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
Abstract, The Aeronautical Journal, vol.90, issue.1028, pp.481-485, 1999. ,
DOI : 10.1017/S0001924000064435
Response surface approximations for structural optimization, International Journal for Numerical Methods in Engineering, vol.24, issue.3, pp.517-534, 1998. ,
DOI : 10.1002/(SICI)1097-0207(19980615)42:3<517::AID-NME370>3.0.CO;2-L
Structural optimization using Kriging approximation, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.7-8, pp.923-939, 2003. ,
DOI : 10.1016/S0045-7825(02)00617-5
Free-form deformation of solid geometric models, Computer Graphics, vol.86, issue.20 4, pp.151-160, 1986. ,
A modified particle swarm optimizer, 1998 IEEE International Conference on Evolutionary Computation Proceedings. IEEE World Congress on Computational Intelligence (Cat. No.98TH8360), 1998. ,
DOI : 10.1109/ICEC.1998.699146
Modelling crack growth by level sets in the extended finite element method, International Journal for Numerical Methods in Engineering, vol.27, issue.8, pp.943-960, 2000. ,
DOI : 10.1002/nme.201
URL : https://hal.archives-ouvertes.fr/hal-01007079
Modeling holes and inclusions by level sets in the extended finite-element method, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.46-47, pp.6183-6200, 2001. ,
DOI : 10.1016/S0045-7825(01)00215-8
URL : https://hal.archives-ouvertes.fr/hal-01007065
Multilevel optimal design of composite structures including materials with negative Poisson's ratio, Structural Optimization, vol.62, issue.17, pp.8-15, 1998. ,
DOI : 10.1007/BF01197432
An augmented Lagrangian relaxation for analytical target cascading using the alternating direction method of multipliers, Structural and Multidisciplinary Optimization, vol.20, issue.3, pp.176-189, 2006. ,
DOI : 10.1007/s00158-005-0579-0
Optimal design of truss structures using parallel computing, Structural and Multidisciplinary Optimization, vol.29, issue.4, pp.285-297, 2005. ,
DOI : 10.1007/s00158-004-0420-1
Particle swarm optimization, AIAA Journal, vol.41, issue.8, 2003. ,
A level set method for structural topology optimization, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.1-2, pp.227-246, 2003. ,
DOI : 10.1016/S0045-7825(02)00559-5
Analysis of the particle swarm optimization algorithm, Master's thesis, 2005. ,
