Should one compute the Temporal Difference fix point or minimize the Bellman Residual? The unified oblique projection view - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Scherrer
We investigate projection methods, for evaluating a linear approximation of the value function of a policy in a Markov Decision Process context. We consider two popular approaches, the one-step Temporal Difference fix-point computation (TD(0)) and the Bellman Residual (BR) minimization. We describe examples, where each method outperforms the other. We highlight a simple relation between the objective function they minimize, and show that while BR enjoys a performance guarantee, TD(0) does not in general. We then propose a unified view in terms of oblique projections of the Bellman equation, which substantially simplifies and extends the characterization of (schoknecht,2002) and the recent analysis of (Yu & Bertsekas, 2008). Eventually, we describe some simulations that suggest that if the TD(0) solution is usually slightly better than the BR solution, its inherent numerical instability makes it very bad in some cases, and thus worse on average.
article.pdf (395.46 Ko) Télécharger le fichier
tdbr.pdf (458.67 Ko) Télécharger le fichier
Format : Autre
inria-00537403 , version 1 (19-11-2010)
  • HAL Id : inria-00537403 , version 1
  • ARXIV : 1011.4362
Bruno Scherrer. Should one compute the Temporal Difference fix point or minimize the Bellman Residual? The unified oblique projection view. 27th International Conference on Machine Learning - ICML 2010, Jun 2010, Haïfa, Israel. ⟨inria-00537403⟩
164 Consultations
746 Téléchargements
