Efficient and Easy Parallel Implementation of Large Numerical Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents an efficient implementation of two large numerical simulations using a parallel programming environment called Athapascan. This library eases parallel implementations by managing communications and synchronization. It provides facilities to adapt the schedule to efficiently map the application to the target architecture.
paper.pdf (130.12 Ko) Télécharger le fichier
inria-00537469 , version 1 (18-11-2010)
Florence Zara, Thierry Gautier, Rémi Revire. Efficient and Easy Parallel Implementation of Large Numerical Simulations. 10th EuroPVM (Parallel Virtual Machine)/MPI (Message Passing Interface), 2003, Venice, Italy. pp.663-666, ⟨10.1007/978-3-540-39924-7_90⟩. ⟨inria-00537469⟩
96 Consultations
128 Téléchargements
