Coupling Parallel Simulation and Multi-Display Visualization on a PC Cluster
Recent developments make it possible for PC clusters to drive multi-display visualization environments. This paper shows how we assembled parallel codes with distributed 3D graphics rendering on a multi-display environment, to enable interaction with complex simulations.
