Higher-order differential properties of Keccak and Luffa - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
In this paper, we identify higher-order differential and zero-sum properties in the full Keccak-f permutation, in the Luffa v1 hash function, and in components of the Luffa v2 algorithm. These structural properties rely on a new bound on the degree of iterated permutations with a nonlinear layer composed of parallel applications of smaller balanced Sboxes. These techniques yield zero-sum partitions of size $2^{1590}$ for the full Keccak-f permutation and several observations on the Luffa hash family. We first show that Luffa v1 applied to one-block messages is a function of 255 variables with degree at most 251. This observation leads to the construction of a higher-order differential distinguisher for the full Luffa v1 hash function, similar to the one presented by Watanabe et al. on a reduced version. We show that similar techniques can be used to find all-zero higher-order differentials in the Luffa v2 compression function, but the additional blank round destroys this property in the hash function.
fullversion.pdf (307.82 Ko) Télécharger le fichier
inria-00537741 , version 1 (19-11-2010)
  • HAL Id : inria-00537741 , version 1
Christina Boura, Anne Canteaut, Christophe de Cannière. Higher-order differential properties of Keccak and Luffa. 2010. ⟨inria-00537741⟩
Collections
INRIA INRIA2 ANR
143 Consultations
240 Téléchargements
