Isogenies and the Discrete Logarithm Problem in Jacobians of Genus 3 Hyperelliptic Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptology Année : 2009
We describe the use of explicit isogenies to translate instances of the Discrete Logarithm Problem (DLP) from Jacobians of hyperelliptic genus 3 curves to Jacobians of non-hyperelliptic genus 3 curves, where they are vulnerable to faster index calculus attacks. We provide explicit formulae for isogenies with kernel isomorphic to $(\ZZ/2\ZZ)^3$ (over an algebraic closure of the base field) for any hyperelliptic genus 3 curve over a field of characteristic not 2 or 3. These isogenies are rational for a positive fraction of all hyperelliptic genus 3 curves defined over a finite field of characteristic $p > 3$. Subject to reasonable assumptions, our constructions give an explicit and efficient reduction of instances of the DLP from hyperelliptic to non-hyperelliptic Jacobians for around 18.57% of all hyperelliptic genus 3 curves over a given finite field. We conclude with a discussion on extending these ideas to isogenies with more general kernels. A condensed version of this work appeared in the proceedings of the EUROCRYPT 2008 conference.
inria-00537851 , version 1 (19-11-2010)
Benjamin Smith. Isogenies and the Discrete Logarithm Problem in Jacobians of Genus 3 Hyperelliptic Curves. Journal of Cryptology, 2009, 22 (4), pp.505-529. ⟨10.1007/s00145-009-9038-1⟩. ⟨inria-00537851⟩
184 Consultations
0 Téléchargements
