Isogenies and the Discrete Logarithm Problem in Jacobians of Genus 3 Hyperelliptic Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Benjamin Smith
We describe the use of explicit isogenies to reduce Discrete Logarithm Problems (DLPs) on Jacobians of hyperelliptic curves of genus three to Jacobians of non-hyperelliptic curves of genus three, which are vulnerable to faster index calculus attacks. We provide algorithms which compute an isogeny with kernel isomorphic to $(Z/2Z)^3$ for any hyperelliptic genus three curve. These algorithms provide a rational isogeny for a positive fraction of all hyperelliptic genus three curves defined over a finite field of characteristic p > 3. Subject to reasonable assumptions, our algorithms provide an explicit and efficient reduction from hyperelliptic DLPs to non-hyperelliptic DLPs for around $18.57\%$ of all hyperelliptic genus three curves over a given finite field.
inria-00537860 , version 1 (19-11-2010)
Benjamin Smith. Isogenies and the Discrete Logarithm Problem in Jacobians of Genus 3 Hyperelliptic Curves. Eurocrypt 2008, International Association for Cryptologic Research, Apr 2008, Istanbul, Turkey. pp.163-180, ⟨10.1007/978-3-540-78967-3_10⟩. ⟨inria-00537860⟩
190 Consultations
0 Téléchargements
