New interface
Conference papers
Optimized decentralization of composite web services
Walid Fdhila 1 Marlon Dumas 2 Claude Godart 1
1 SCORE - Services and Cooperation
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : Composite services are usually specified by means of or- chestration models that capture control and data-flow rela- tions between activities. Concrete services are then assigned to each activity based on various criteria. In mainstream service orchestration platforms, the orchestration model is executed by a centralized orchestrator through which all interactions are channeled. This architecture is not optimal in terms of communication overhead and has the usual problems of a single point of failure. In previous work, we proposed a method for executing service orchestrations in a decentralized manner while fulfilling collocation and separation constraints. However, this and similar methods for decentralized orchestration do not seek to optimize the communication overhead between services participating in the orchestration. This paper presents a method for optimizing the selection of services assigned to activities in a service orchestration in terms of QoS properties and communication overhead. The method takes into account the communication cost between pairs of services, the amount of data that these services need to exchange in the orchestration, and the collocation and separation constraints imposed by the service providers.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00537925
Contributor : Walid Fdhila Connect in order to contact the contributor
Submitted on : Tuesday, November 22, 2011 - 7:32:25 PM
Last modification on : Thursday, April 7, 2022 - 3:08:59 AM
Identifiers
  • HAL Id : inria-00537925, version 1
Collections
Citation
Walid Fdhila, Marlon Dumas, Claude Godart. Optimized decentralization of composite web services. 6th International Conference on Collaborative Computing: Networking, Applications and Worksharing - CollaborateCom 2010, Oct 2010, Chicago, United States. ⟨inria-00537925⟩
Share
Metrics
Record views
55
