Cooperative task management without manual stack management, Proceedings of the 2002 USENIX Annual Technical Conference, pp.289-302, 2002. ,
Compiling with continuations, 1992. ,
DOI : 10.1017/CBO9780511609619
Réalisation d'un seeder bittorrent en CPC URL http://www.pps.univ-paris-diderot.fr/ ~ jch/software/hekate/hekate-attar-canal Capriccio: scalable threads for internet services, SIGOPS Oper. Syst. Rev, vol.37, issue.5, pp.268-281, 2003. ,
FairThreads: mixing cooperative and preemptive threads in C, Concurrency and Computation: Practice and Experience, vol.11, issue.5, pp.445-469, 2006. ,
DOI : 10.1002/cpe.919
URL : https://hal.archives-ouvertes.fr/inria-00071544
Representing control in the presence of one-shot continuations, Proceedings of the ACM SIGPLAN 1996 conference on Programming language design and implementation, PLDI '96, pp.99-107, 1996. ,
Continuation-passing for C: a space-efficient implementation of concurrency, Tech. rep., PPS, Université Paris, vol.7, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00135160
A poor man's concurrency monad, Journal of Functional Programming, vol.9, issue.3, pp.313-323, 1999. ,
DOI : 10.1017/S0956796899003342
Proper tail recursion and space efficiency, Proceedings of the ACM SIGPLAN 1998 conference on Programming language design and implementation, PLDI '98, pp.174-185, 1998. ,
DOI : 10.1145/277652.277719
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.4500
Lambda-Lifting in Quadratic Time, Functional and Logic Programming, pp.134-151, 2002. ,
DOI : 10.1007/3-540-45788-7_8
The Native POSIX Thread Library for Linux URL http://people.redhat.com/drepper/nptl-design.pdf 13. Duff, T.: Duff's device, 1983. ,
Protothreads, Proceedings of the 4th international conference on Embedded networked sensor systems , SenSys '06, pp.29-42, 2006. ,
DOI : 10.1145/1182807.1182811
Engines from continuations, Computer Languages, vol.14, issue.2, pp.109-123, 1989. ,
DOI : 10.1016/0096-0551(89)90018-0
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.64.6124
Portable multithreading: the signal stack trick for user-space thread creation, Proceedings of the 2000 USENIX Annual Technical Conference. USENIX Association, 2000. ,
Specification and Correctness of Lambda Lifting, J. Funct. Program, vol.13, pp.509-543, 2003. ,
DOI : 10.1007/3-540-45350-4_10
Tasks, Proceedings of the 2007 ACM SIGPLAN symposium on Partial evaluation and semantics-based program manipulation , PEPM '07, pp.134-143, 2007. ,
DOI : 10.1145/1244381.1244403
Trampolined style, Proceedings of the fourth ACM SIGPLAN international conference on Functional programming, ICFP '99, pp.18-27, 1999. ,
DOI : 10.1145/317636.317779
Scala Actors: Unifying thread-based and event-based programming, Theoretical Computer Science, vol.410, issue.2-3, pp.202-220, 2009. ,
DOI : 10.1016/j.tcs.2008.09.019
URL : http://doi.org/10.1016/j.tcs.2008.09.019
AC: composable asynchronous IO for native languages, Proceedings of the 2011 ACM international conference on Object oriented programming systems languages and applications, pp.903-920, 2011. ,
Continuations and coroutines, Proceedings of the 1984 ACM Symposium on LISP and functional programming , LFP '84, pp.293-298, 1984. ,
DOI : 10.1145/800055.802046
Monitors: an operating system structuring concept, Communications of the ACM, vol.17, issue.10, pp.549-557, 1974. ,
DOI : 10.1145/355620.361161
Lambda lifting: Transforming programs to recursive equations, Lecture Notes in Computer Science, vol.201, pp.190-203, 1985. ,
DOI : 10.1007/3-540-15975-4_37
Are events fast? Tech. rep, 2009. ,
CPC: programming with a massive number of lightweight threads, Proceedings of the Workshop on Programming Language Approaches to Concurrency and Communication- Centric Software, PLACES ', p.11, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00563369
Lambda-lifting and CPS conversion in an imperative language, Tech. rep., PPS, Université Paris, vol.7, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00669849
Weave: translated threaded source (with annotations) to fibers with context passing (ca As used within RAID-1 code in IBM SSA RAID adapters, 1995. ,
Events can make sense, Proceedings of the 2007 USENIX Annual Technical Conference, pp.1-14, 2007. ,
Correspondence between ALGOL 60 and Church's Lambda-notation: part I, Communications of the ACM, vol.8, issue.2, pp.89-101, 1965. ,
DOI : 10.1145/363744.363749
The Objective-Caml system, 2010. ,
Combining events and threads for scalable network services implementation and evaluation of monadic, application-level concurrency primitives, Proceedings of the 2007 ACM SIGPLAN conference on Programming language design and implementation, PLDI '07, pp.189-199 ,
Garbage collection is fast, but a stack is faster. AI Memo 1462, 1994. ,
CIL: Intermediate Language and Tools for Analysis and Transformation of C Programs, Compiler Construction, pp.209-265, 2002. ,
DOI : 10.1007/3-540-45937-5_16
Flash: an efficient and portable web server, Proceedings of the 1999 USENIX Annual Technical Conference. USENIX Association, 1999. ,
Call-by-name, call-by-value and the ??-calculus, Theoretical Computer Science, vol.1, issue.2, pp.125-159, 1975. ,
DOI : 10.1016/0304-3975(75)90017-1
Concurrent ML: Design, application and semantics, Lecture Notes in Computer Science, vol.693, pp.165-198, 1993. ,
DOI : 10.1007/3-540-56883-2_10
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.7965
The discoveries of continuations, LISP and Symbolic Computation, vol.24, issue.3, pp.233-247, 1993. ,
DOI : 10.1007/BF01019459
Implementing first-class polymorphic delimited continuations by a type-directed selective cps-transform, Proceedings of the 14th ACM SIGPLAN international conference on Functional programming, ICFP '09, pp.317-328, 2009. ,
A concurrency monad based on constructor primitives, or, being first-class is not enough, 1995. ,
State Threads for internet applications, 2009. ,
Kilim: Isolation-Typed Actors for Java, ECOOP 2008 ? Object-Oriented Programming, pp.104-128, 2008. ,
DOI : 10.1007/978-3-540-70592-5_6
Rabbit: A compiler for Scheme Master's thesis, 1978. ,
Lambda, the ultimate imperative. AI Memo 353, 1976. ,
Continuations: A mathematical semantics for handling full jumps, Reprinted in Higher-Order and Symbolic Computation, pp.135-152, 1974. ,
URL http://www.chiark.greenend.org.uk/ ~ sgtatham/coroutines.html 48. Thielecke, H.: Continuations, functions and jumps, Coroutines in C SIGACT News, vol.30, issue.2, pp.33-42, 1999. ,
Continuations and stackless Python, Proceedings of the 8th International Python Conference, 2000. ,
Lwt, Proceedings of the 2008 ACM SIGPLAN workshop on ML, ML '08, pp.3-12, 2008. ,
DOI : 10.1145/1411304.1411307
URL : https://hal.archives-ouvertes.fr/hal-00495983
Continuations revisited. Higher-Order and Symbolic Computation, pp.131-133, 2000. ,
Continuation-based multiprocessing, Proceedings of the 1980 ACM conference on LISP and functional programming , LFP '80, pp.19-28, 1980. ,
DOI : 10.1145/800087.802786
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.44.5351
SEDA, ACM SIGOPS Operating Systems Review, vol.35, issue.5, pp.230-243, 2001. ,
DOI : 10.1145/502059.502057
Recursive definition of syntax and semantics. In: Formal Language Description Languages for Computer Programming, pp.13-24, 1966. ,
