FORUM: A flexible data integration system based on data semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIGMOD record Année : 2010
FORUM : un système d'intégration de données flexible basé sur la sémantique des données
The FORUM project aims at extending existing data integration techniques in order to facilitate the development of mediation systems in large and dynamic environments. It is well known from the literature that a crucial point that hampers the development and wide adoption of mediation systems lies in the high entry and maintenance costs of such systems. To overcome these barriers, the FORUM project investigates three main research issues: (i) automatic discovery of semantic correspondences (ii) consistency maintenance of mappings, and (iii) tolerant rewriting of queries in the presence of approximate mappings.
FORUM_A_Flexible_data_Integration_System_Based_on_.pdf (708.77 Ko) Télécharger le fichier
hal-02593758 , version 1 (11-09-2020)
Zohra Bellahsene, Salima Benbernou, Hélène Jaudoin, François Pinet, Olivier Pivert, et al.. FORUM: A flexible data integration system based on data semantics. SIGMOD record, 2010, 39 (2), pp.11-18. ⟨10.1145/1893173.1893175⟩. ⟨hal-02593758⟩
508 Consultations
59 Téléchargements
