New interface
Conference papers
Flexible Model Element Introduction Policies for Aspect-Oriented Modeling
Brice Morin 1 Jacques Klein 2 Jörg Kienzle Jean-Marc Jézéquel 1
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Aspect-Oriented Modeling techniques make it possible to use model transformation to achieve advanced separation of concerns within models. Applying aspects that introduce model elements into a base model in the context of large, potentially composite models is nevertheless tricky: when a pointcut model matches several join points within the base model, it is not clear whether the introduced element should be instantiated once for each match, once within each composite, once for the whole model, or based on a more elaborate criteria. This paper argues that in order to enable a modeler to write semantically correct aspects for large, composite models, an aspect weaver must support a flexible instantiation policy for model element introduction. Example models highlighting the need for such a mechanism are shown, and details of how such policies can be implemented are presented.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00538458
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Monday, November 22, 2010 - 3:22:49 PM
Last modification on : Friday, February 4, 2022 - 3:23:17 AM
Long-term archiving on: : Wednesday, February 23, 2011 - 2:49:43 AM
File
Morin10c.pdf
Identifiers
  • HAL Id : inria-00538458, version 1
Citation
Brice Morin, Jacques Klein, Jörg Kienzle, Jean-Marc Jézéquel. Flexible Model Element Introduction Policies for Aspect-Oriented Modeling. 13rd ACM/IEEE International Conference on Model-Driven Engineering Languages and Systems (MODELS 2010), 2010, Oslo, Norway, Norway. ⟨inria-00538458⟩
Share
Metrics
Record views
206
Files downloads
231
