Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, issue.4, pp.471-480, 1973. ,
DOI : 10.1109/TIT.1973.1055037
The rate-distortion function for source coding with side information at the decoder, IEEE Transactions on Information Theory, vol.22, issue.1, pp.1-10, 1976. ,
DOI : 10.1109/TIT.1976.1055508
An optimal distributed and adaptive source coding strategy using rate-compatible punctured convolutional codes, ICASSP, vol.3, pp.685-688, 2005. ,
Compression of correlated binary sources using turbo codes, IEEE Communications Letters, vol.5, issue.10, pp.417-419, 2001. ,
DOI : 10.1109/4234.957380
Compression of binary sources with side information at the decoder using LDPC codes, IEEE Communications Letters, vol.6, issue.10, pp.440-442, 2002. ,
DOI : 10.1109/LCOMM.2002.804244
The DISCOVER Codec: Architecture, techniques and evaluation, PCS, 2007. ,
Recent results in the Shannon theory, IEEE Transactions on Information Theory, vol.20, issue.1, pp.2-10, 1974. ,
DOI : 10.1109/TIT.1974.1055171
Regular and irregular progressive edge-growth tanner graphs, IEEE Transactions on Information Theory, vol.51, issue.1, pp.386-398, 2005. ,
DOI : 10.1109/TIT.2004.839541
Rate-adaptive codes for distributed source coding, Signal Processing, vol.86, issue.11, pp.3123-3130, 2006. ,
DOI : 10.1016/j.sigpro.2006.03.012
